Question about Goldstar Dehumidifiers
Goldstar DH404EY5 dehumidifier. Humidity control goes to 01% and can't be adjusted. Bucket Full light is flashing,not steady on.Micro switch won't reset it. What is this?
Posted by Jim Thomas on
5 Related Answers
Anonymous
SOURCE: Dehumidifier Error?
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
Posted on Nov 13, 2008
Anonymous
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
Posted on May 02, 2009
Ron Brown
SOURCE: Bucket full light flashing but not full, humidity % shows as 01%
I posted an extended answer to this problem with part replacement info and pictorial. Why hasn't this solution been posted???
[email protected] .net
Posted on Mar 04, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: bucket full light flashes, humidity
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Posted on Jun 10, 2011
doug
  • 4 Answers
SOURCE: dehumidifier model lhd459el bucket full
I had same problem but fortunatly had two units (one working other not) tried swapping capacitor / thermal switch with no luck, removed plug into circuit board for humidity sensor and bucket switch.now both units work, this tells me it was simply a bad connection of the board. hope this helps someone.
Posted on Sep 04, 2012
RED BUCKET LIGHT FLASHES OFF & ON HUMIDITY SAYS 01 NOTHING HAPPENS
heatman101
Jun 13, 2011 | Dehumidifiers
Bucket full light flashes, humidity setting won't change - only says 01
heatman101
Jun 07, 2011 | LG LHD459EL Dehumidifier
Unit just won't work anymore .
I have a model dh404e with the same problem.I was told it is the main control board inside the unit(not dislpay board) but a new board costs around $60.
Feb 20, 2010 | Goldstar DH504EL Dehumidifier
Jan 28, 2010 | Kenmore 54501 Dehumidifier
NO POWER WHEN PLUGGED IN, NO DIGITAL READ OUTS
1) check power outlet
2) remover cabinet and check glass fuse on power supply board that power cord attaches to.
Jan 04, 2010 | Goldstar DH504EL Dehumidifier
Dehumidifier Error?
May 09, 2008 | Kenmore 54701 Dehumidifier
Dehumidifier Error?
May 29, 2007 | LG DH504E GoldStar Dehumidifier
Dehumidifiers Logo
153 people viewed this question
Top Goldstar Dehumidifiers Experts
Sheldon Dedek
Tim Venetis
Tom Chichester
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
