Question about Crock Pots & Slow Cookers
Hb set and forget crock pot whs cooking a meal and looked at it hour later crock pot hot no lights on display ...pushed on off it just blinked wont turn setting lights on
Posted by 101nobull on
5 Related Answers
Anonymous
SOURCE: Crock pot dish in the oven
1-800-323-9519 Rival's phone number.
From the horses mouth: The stoneware insert can withstand 380degrees fahrenheit, sans glass lid.
You are fine.
Posted on Dec 12, 2008
Anonymous
SOURCE: crock pot
I had the same problem this morning (E01 error message). I unplugged the crock pot and held the "cook" button while I plugged it in. It reset and all is working fine now.
Posted on Jan 23, 2009
Anonymous
SOURCE: crock pot overheating
my 38601 smart pot 6 qt has all of its items cooked at 3-4 hrs when I have it on low heat setting at 10hrs WHY?
Posted on Jan 24, 2009
Anonymous
SOURCE: Why do the new Crock Pots cook so much faster than
Replaced the new one in the kitchen with the old one I put out to pasture. Problem solved. I'm back in the slow cooking business.
Posted on Oct 10, 2009
Anonymous
  • 18 Answers
SOURCE: rival crock pot smart pot - low, keep warm
Some times it can be fix wit heat element.The manufacturer may have this part available to buy.Go to the website with your model number.Find it buy it install it do it your self and save.It may need some soldering done,or it may just unplug.Good Luck!
Posted on Aug 08, 2010
Can it take meat and vegetables at the same time?
I make a great tender roast in crock pot with meat potatoes carrots onions put all of this in crock pot at one time add 1 cup water and one envelope dry onion soup mix mixed with another cup of water and pour over entire ingredients placed in crock pot . turn on med setting and cook for the day .It's a meal in one !
Oct 23, 2015 | Crock Pots & Slow Cookers
How long should i cook on high a full crock pot with vegetables and raw meat
when do you want to eat? It usual takes a good six hours on high.
Dec 31, 2012 | Rival Crock Pots & Slow Cookers
Have lost instruction book, how do I use it?
What sort is it? I have a Sunbeam - I just throw in all the ingredients for say, a casserole, in the morning before work. Leave it on low heat setting, ensuring that I have a tin of tomatoes or a mug of beef or chicken stock to keep everything moist, put the lid on and about 7 hours later hey presto! The meal is ready. No real preparation , I just use a normal meal recipe, and ensure i have enough moisture for the cooking as I would in the oven.
Apr 10, 2011 | Crock Pots & Slow Cookers
Just been given crock pot with 3 settings can you explain them no manual came with pot
It sure would help us to help you if you could get the model number off of the bottom of the unit. I can probably locate a user's manual with that information. Try this site to locate the manual: (my best guess without a model number)
http://safemanuals.com/314159.php?k=84c8d7db0922eceeab89e8e236b92e45&ID=2854106&q=CROCK%20POT%20SMART%20POT
(209k)
Find the little blue print that says enter security code and then you can dounload the manual.
The settings should be OFF High 4 High 6, Low 8 Low 10 and warm.
1. Place food in stoneware according to recipe.
2. Plug in Smart-Pot™ slow cooker. The Power light will begin to flash
indicating that the unit is plugged in, but not turned on.
HOW TO PROGRAM YOUR SMART-POT™ (CONT.)
3. Push the Cook Time button to scroll through the timed cooking
options. Push once and the 4 hour light will illuminate, twice and the
6 hour light will come on, etc. Select the time based on the length of
time indicated in the recipe. Two time options are usually given. The 4
and 6 hour settings are the HIGH temperature setting and may be
used when you want your food done quicker. The 8 and 10 hour
settings correspond to the LOW temperature setting and is used for all
day cooking. In addition your Smart-Pot™ can be set to the Warm
Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use
the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Pot™ slow cooker will
automatically shift to the Warm setting and the Warm light will come
on. NOTE: We do not recommend using the Warm setting for more
than 4 hours.
5. To turn the Smart-Pot™ off push the OFF button. Unplug unit from the
wall outlet.
6. For other recipes that give a range of times, select the time closest
to the setting on your Smart-Pot™. For instance a recipe calling for
cooking time of 7 to 9 hours on LOW, set your Smart-Pot™ to 8 hours.
NOTE: If power goes off then power light will blink and settings must be
reset. If cook time is changed before the cycle is complete the time will
reset to the new setting.
Thanks for choosing FixYa,
Kelly
Mar 04, 2011 | Rival 38601 Smart Pot 6-Quart
I need the user instructions for use
Hi and welcome to FixYa, I am Kelly
I see I am nearly a month late in replying to your post. I just answered another post and when I finished I saw your question.
This is driectly from the user's manual that you can find here with some difficulty:
(Avoid answering questions by looking for the blue text that says "security code" and clicking that) Then enter the 4 digit code to download the manual that is 209k)
2. Plug in Smart-Pot slow cooker. The Power light will begin to flash indicating that the unit is plugged in, but not turned on.
3. Push the Cook Time button to scroll through the timed cooking options. Push once and the 4 hour light will illuminate, twice and the 6 hour light will come on, etc. Select the time based on the length of time indicated in the recipe. Two time options are usually given. The 4 and 6 hour settings are the HIGH temperature setting and may be used when you want your food done quicker. The 8 and 10 hour settings correspond to the LOW temperature setting and is used for all day cooking. In addition your Smart-Pot can be set to the Warm Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Pot slow cooker will automatically shift to the Warm setting and the Warm light will come on. NOTE: We do not recommend using the Warm setting for more than 4 hours.
5. To turn the Smart-Pot off push the OFF button. Unplug unit from the wall outlet.
6. For other recipes that give a range of times, select the time closest to the setting on your Smart-Pot. For instance a recipe calling for cooking time of 7 to 9 hours on LOW, set your Smart-Pot to 8 hours.
NOTE: If power goes off then power light will blink and settings must be reset. If cook time is changed before the cycle is complete the time will reset to the new setting.
That is pretty much the entire user instructions. Everything else is warnings, cautions, and oh yes; don't submerge it in water yadda yadda....
Kelly
Feb 05, 2011 | Rival 38601 Smart Pot 6-Quart
I need an owners manual for the SCVC651
I couldn't find the specific manual for this, but I did find some basic instructions on a personal review:
"Rival calls this a SmartPot and describes this unit as "programmable". All this really means is that you can program the slow cooker to cook either on "High" or "Low" for up to 20 hours, in 30 minute increments and then it will automatically switch to the "Keep Warm" setting and keep your meal warm for hours. You cannot program multiple steps, such as going from the "High" to the "Low" setting. The red, LCD clearly displays the remaining cook time.
Simply plug in the slow cooker, and then push the clearly marked buttons (with a pleasant, audible tone) to move from "Low" to "High" to "Keep warm" settings. Then push the Timer Button to set the desired cook time."
Hopefully, this helps answer your questions!
Nov 23, 2010 | Rival SCVC651-F Slow Cooker
How do I start the cooker on low?
The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
Dec 18, 2009 | CorningWare SC60 Slow Cooker
Can I reheat foods in my Rival Slow Cooker?
No, it's not really safe (the food may not reach a high enough temp.)
Also, if you did try, it would take hours to get hot enough &the food wouldn't be as appealing--dried out etc.
Try reheating in your microwave instead.
For more ??s check
http://www.crock-pot.com
Dec 21, 2008 | Crock Pots & Slow Cookers
Crock pot overheating
Dec 08, 2008 | Rival 38601 Smart Pot 6-Quart
It wont heat up and all the lights just keep blinking
I have the same problem EVERY time I want to use the crock pot. My solution has be patience. I find that if I turn it on, and the light blinks, but when i click it it will blink on 4 hours, then go back to the blinking light. By keeping the crock pot plugged in and off for about 10-15 minutes I was then able to set the crockpot up for cooking. As if the capacitors inside the unit needed power stored in them from the wall.
Dec 21, 2007 | Rival 5865-W 6.5-Quart Slow Cooker
Crock Pots & Slow Cookers Logo
135 people viewed this question
Top Crock Pots & Slow Cookers Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
