Question about Universal Televison & Video
I have a 5 in 1 universal remote and i need to program it to my amp tv because my sound will not work well it's connected to my suddenlink cable box
Posted by Cody Galloway on
5 Related Answers
Anonymous
  • 129 Answers
SOURCE: universal remote code needed for motorola cable box (for comcast)
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC8800
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 21, 2007
Anonymous
SOURCE: universal remote code for samsung bluray dvd player
I have a Samsung blu-ray dvd player,non of the codes seem to work with my universal remote.
Help.
Posted on Dec 14, 2008
Anonymous
  • 52 Answers
SOURCE: Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Posted on Jun 18, 2009
Anonymous
SOURCE: Need universal remote code for Humax ND-1000C satellite cable box
Put 0 0 0 0 as a code.
Posted on Jul 07, 2009
Kim Hake
SOURCE: Can't get universal remote or cable remote to work with my tv.
I need programming instructions for proscan universal remote control. I have code.
Posted on Apr 28, 2010
Can i use an Onn Universal remote for a Suddenlink cable receiver?
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Try the set-up codes for Suddenlink cable box. If you can't find any code there, try a code-search procedure.
Nov 06, 2014 | Onn ONA12AV058 Universal Remote Control -...
Samsung Smart TV Universal Remote setup with sudden link
We need to know the model numbers of the television and the set top box and the remote.
Nov 24, 2013 | Samsung Televison & Video
Sudenlink remote not working for cable box
Hi rydenkd- My name is Shannon and I am with Suddenlink. Please visit our self-help site to troubleshoot and reprogram your remote here: http://help.suddenlink.com/Television/Pages/RemoteControls.aspx. If you still run into difficulty, please feel free to contact me directly at shannon-AT-suddenlink-DOT-com. Thanks!
Jan 23, 2013 | Televison & Video
I need to program my suddenlink remote to this tv
Hi- My name is Shannon and I am with Suddenlink. If you are still having trouble programming your remote please visit our self-help site at http://help.suddenlink.com/Television/Pages/RemoteControls.aspx. You can choose the type of remote you have and it will pull up a list of usable codes. Thanks!
Jan 17, 2013 | LG Televison & Video
I need to program my suddenlink remote code to work for my motorola suddenlink cable box so that my volume button can work.
Hi- My name is Shannon and I am with Suddenlink. If you are still having trouble programing your remote, you can find all the codes on our Suddenlink Support site, here: http://help.suddenlink.com/Television/Pages/RemoteControls.aspx. Thanks!
Nov 19, 2012 | Televison & Video
Sync to my suddenlink box to change the channels
Hi - Tina from Suddenlink here. Please check our help site for instructions on how to program your remote: http://help.suddenlink.com/Television/Pages/RemoteControls.aspx
Aug 29, 2012 | Philips Srp4004/27 Universal 4 In 1 Remote...
I'm trying to program my cable button on my suddenlink atalas 1056b01 remote. I have gotten the TV button to work, and I can try the device off and on..I'm just having a hard time getting the cable...
Hi - My name is Tina and I am with Suddenlink. I'm not sure which website you have visited for your remote control -- but this is the one I usually use: http://help.suddenlink.com/Television/Pages/RemoteControls.aspx
If you are still having issues programming your remote, please feel free to contact me via email at tina-AT-suddenlink-DOT-com. Thanks!
Jun 14, 2011 | Televison & Video
Where do i look for the tv codes to program the tv set to a suddenlink universal tv remote
Hi - My name is Tina and I am with Suddenlink. Please check our support site here for more info on programming your remotes. If you need further assistance, please contact me at tina-AT-suddenlink-DOT-com. Thanks!
Aug 10, 2010 | Televison & Video
Need code to program my remote control
I have the RCRP05B RCA Universal Remote and need the code for my SuddenLink Cable/DVR box which is a Motorola DCT6416 iii.
Jun 19, 2010 | Innovage Jumbo Remote Control
Televison & Video Logo
55 people viewed this question
Top Universal Televison & Video Experts
JOHN TOPLISS
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
