Question about One For All Televison & Video
SOURCE: converter box codes for rca universal remote rcr3273/3373 for zenith or lg boxes
if It is similar to most RCA universal remotes, to get the code follow these steps(Manual code search MAy take awhile):
1:Manualy turn on the component that u want to control
2: press and hold the component key (ie SAT while holding SAT press
ON-OFF key(button) for three seconds until all of the components light
up and release the keys(button).
3: keep pressing ON-OFF key until your component turns off.(Note may take awhile)
4: one the correct code is found hit the STOP key and it will save your
component IF YOU DO NOT HIT THE STOP KEY THE CORRECT CODE WILL NOT BE
STORED.
Hope this works
Posted on Oct 26, 2008
SOURCE: program my zenith converter box to my tv
while holding down the tvs power button push the channel up or down slowly. this will turn your tv off when your code is found. when it is found and your tv goes off release the power button. now your remote will work with your tv...........
Posted on Jan 02, 2009
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable. The Installation Guide should appear. The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Posted on Jan 17, 2009
SOURCE: Have RCR4358 need codes to program for "Insignia set-top box"
Rca web site for your coses
http://66.77.167.109/rcaaccessories/RcaaccessoriesController.do?ACTION_TYPE_ID=ACTION_TYPE_CATEGORY&ACTION_CATEGORY_ID=STR_CATEGORY_REMOTE_FINDER
Posted on Mar 04, 2009
SOURCE: Zenith mbr3447 code for magnavox converter box?
To download the full code list with the instructions on how to program go to link below:
http://www.replacementremotes.com/store/productdetailp.cfm?productid=61978&reset=1
if your none of the codes work for you cable box then your SOL. try programming your cable box remote for your tv instread.
Posted on Apr 23, 2009
Dec 15, 2015 | Zenith Televison & Video
Apr 22, 2012 | Philips Universal Remote
May 16, 2011 | Insignia Televison & Video
Jan 15, 2009 | Zenith MBR3447 Remote Control
Nov 21, 2008 | Zenith DBZN-311 Remote Control
Oct 26, 2008 | Insignia Digital-to-Analog Converter for...
Oct 23, 2008 | Televison & Video
64 people viewed this question
