Question about Furniture
My Marvel model 30WCCBSG wine cooler is Not cooling as it should. What can be the problem ?
Posted by rcrc on
3 Related Answers
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Posted on Mar 01, 2008
subdriver
  • 101 Answers
SOURCE: Marvel wine refrigerator running,but not cooling
If your unit runs but does not cool, you have a "sealed system" issue. Either you are low on refrigerant which would be evident by frost build-up near the area where the freon first enters the evaporator plate. (lower middle, then travels left) or the compressor has lost the ability to develop the necessary differential pressure. You do not want to run the unit like that...you can **** in contaminants that will harm the compressor if you already haven't. You should contact a servicer to get it repaired. If you are still within the warranty period you should contact the dealer you got it from to initiate service.
Posted on Sep 15, 2009
subdriver
  • 101 Answers
SOURCE: Marvel 61wc wine cooler turns on, but doesn't cool
If you can hear the compressor running and there is no cooling happening your unit has either lost it's refrigerant due to a leak or the compressor is completly worn out (or both). If you just hear the condenser fan running (air blowing), then maybe the compressor just has bad electricals (starting relay, overoad, run capactor) or it has developed a bad winding and will need to be replaced.
If you know you have lost refrigerant the repair will be quite costly and you should consider replacement. If you feel it is a failure of the small electrical parts for the compressor, repair would be more cost effective.
You can get further trouble-shooting assistance and order parts direct from the factory at 800-223-3900.
You can look up a local servicer on their web-site at www.lifeluxurymarvel.com
Should you desire to attempt electrical repair yourself, reply to me and I will provide further troubleshooting assistance or you can contact Marvel Customer Service at the number above. Good-Luck, Subdriver
Posted on Feb 05, 2010
Why does my wine cooler run too cold?
If after adjusting your thermostat to desired temp and is still cooling. The thermostat is bad or your relay is bad
If you disconnect the thermostat and the compressor stops it most likely a bad thermostat
If you disconnect the relay from
The thermostat and it stay running it is the relay. It is sticking
If possible store you wine somewhere else and shut the unit down and unplug for 10 to 20 minutes this may cause some melt of condensation some water may be on the floor if is to cold
This may also reset the system.
Jul 26, 2015 | Marvel 61WC Wine Cooler
What freon is in marvel wine cooler 61 WCMA
Don't know, but their should be a label on or near the compressor that tells you.
Mar 01, 2015 | Marvel (6SBARBSG) Wine Cooler
Marvel 6BAR6004 not cooling
check you themoistat it may be coated with sofa
Jul 04, 2014 | Marvel 61WC Wine Cooler
I have a marvel wine cooler that frosts up and also tends to have temperture issues. Bottles on second shelf freeze. Temp adjustments to less cold make it too warm.
you have a restriction in the cooling side sounds like the filter line dryer is clogged up and will need to be replaced. Also the system will have to be recharged by a professional check to see if its in warranty.
Dec 17, 2010 | Marvel 6BAR Wine Cooler
Not cooling and frosting up on the upper right side in back
Sounds like a leak in the refrigerant system. Need a certified technician for this repair.
Apr 22, 2010 | Marvel (6SBARBSG) Wine Cooler
Jan 28, 2010 | Marvel 61WC Wine Cooler
I have the Marvel 70 bottle wine cooler and it is making loud whining noise like if you put a stick in the wheel of spinning bike spokes when it is cooling down sometimes. it does not seem to be the fan...
I believe the 6SBAR has an evaporator fan located behind the evaporator plate ( the cooling plate) inside the unit. They had some issues with the bearings in those fans failing and will sound like a small jet engine sometimes (high pitched whine). When you hear the noise, open the door and if the noise level changes (either gets louder or goes away) then it is the evaporator fan. If your noise is coming from the compressor area and does not change when you open the door, it is most likely the condenser fan blade is loose. The evaporator fan looks like a small computer cooling fan and is located near the bottom center of the evaporator plate (out of site). The factory sells a replacement kit with a much better fan and new power supply. You can reach them at 800-223-3900. Good-luck.
Nov 19, 2009 | Marvel (6SBARBSG) Wine Cooler
Marvel Cooler/Fridge Light Not Working
It sounds like the bulb is not getting power. There is a door switch that turns it off when the door closes...this may be stuck. There is usually an optional (depending on age) ON/OFF switch that overrides the light to be on full time. If the light will also not turn on with that switch then there must be a disconnected or broken wire either going to the light switches or going to the light socket from the switches. I hope this helps.
Aug 30, 2008 | Marvel (6SBARBSG) Wine Cooler
Dec 02, 2007 | Marvel 61WC Wine Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Furniture Logo
151 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
