Question about Samsung Audio Players & Recorders
How do I play CD on Samsung HT-Q70? - Samsung Audio Players & Recorders
Posted by Hal Ward on
5 Related Answers
johnychel
isaac johny
  • 796 Answers
SOURCE: i have a samsung ht-tx72
are both of the dvd and cd that you are using are of 12cm diameter one...
if the size varies may be it is touching the edges
Posted on Apr 11, 2008
Anonymous
SOURCE: Cannot turn TV off when playing CD's with samsung HT-X810R/LG50PG
Problem traced to Samsung's Anynet+ System interacting with LG's Simplink. They seem to be
compatible. Cured by Menu/Option/Simplink/OFF. Hope this helps with anyone else having this problem. trev6.
Posted on Jan 10, 2009
Anonymous
  • 113 Answers
SOURCE: how do i connect/play my turntable?
Hi sorry to say cant go direct.
What you can do if really want it running is get a RIAA pre amp with power supply (search google local shops). The turn table plugs into that, then that plugs into one of the analogue inputs of the Q70. That will work great if prepared for the effort!
Best of luck
Posted on Jul 22, 2009
Anonymous
  • 1056 Answers
SOURCE: I just want to know if I can connect my laptop to
Yes you can and it is very simple. All you need is a special wire. One end fits to the earphone jack on the laptop, and the other end looks like rca cable. At the back of your home theater choose aux in, and connect the rca end of the cable to that. Then the other end looks like a headphone jack, and you connect that to the laptop headphone jack. Now on you home theater select aux. You will everything that comeout of that laptop including the windows vista melody when you first boot it up. Now you are ready to enjoy music.
Posted on Nov 23, 2009
When a movie is playing, you can hear all sounds except the actors voices....they are mumbled.
The voices are probably coming out on one of the channels that has a bad speaker, bad wire, loose connector, or bad output. If you have the audio set to 5.1 output, change it to two-channel stereo output. The voices should return to normal.
The system plays the music but the voices are mumbled.
Look on the remote for "mode", "effect" and or the "sound edit" buttons. There are a few different sound effects to choose from.
Your manual:
http://downloadcenter.samsung.com/content/UM/200603/20060310100609484_Q70_XAA_ENG.pdf
My Samsung HT-Q70 5 disc drawer won't stay closed. It doesn't matter if a disc is in or out or radio selected or anything, it just pops out. Anyone with an idea??
make sure its fully cleaned. many appliances will automaticly open the disktray if there is a reading error. DO NOT TOUCH THE LENS. i suggest a simple blow over the lens and cleaning the disk, try again. if all else fails, contact your seller and get a trade in.
I just want to know if I can connect my laptop to my Samsung HT-Q70 Home Theater System for audio so I can hear the sound from the laptop on my Home Theater speakers?
How do i connect/play my turntable?
Best of luck
Samsung ht-q70
You can try fixing it yourself Front Board part # AH92-02494A FROM SEARS $45.27 + $10.99 S/H but it can happen again.
2helpful
2answers
LCD Display Failure
Found this information for a Samsung unit with the same internal components experiencing the same problems. http://www.fixya.com/support/t194959-display_sound. I know this drove me nuts so hopefully it will help others.
Playing cd's
call the tech he will be able to tell you what is the problem with your set the microchip could be the problem.good luck.
6helpful
Swa3000
  1. With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
    Note: You can release the REMAIN button when the POWER LED blinks blue/Red depending on model.
  2. With the SWA-3000 turned on, use a ball point pen to press the RESET button on the back of the SWA-3000. The POWER LED in the front of the home theater blinks two times.
Top Samsung Audio Players & Recorders Experts
 Francisco Mauricio...
Joaquim Martins
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
