DAA78L Kara_MB 13127 1 348.01404.0011 does it support port multiplier
How i change size from MB to KB
There are 1000KB in 1MB, so multiply the number of MB by 1000 to get the number of KB.
Apr 27, 2012 | Cameras
Sound driver
First, make sure your speakers are on, the volume is up, plugged into the correct port on the computer and the sound setting in you computer's operating system is not muted. If that doesn't work probably do need a driver.
If the sound port is on the motherboard go to your MB manufacturer's website and locate the sound or audio driver that matches your MB and operating system. The MB ports are usually grouped together so the sound port would be near the keyboard, mouse and USB ports.
If the sound port is on an add-on card (PCI /PCI-E) then go to the card maker's website and locate the sound or audio driver that matches your MB and operating system.
I hope this helps. Good luck!
Jan 16, 2011 | Computers & Internet
Intel d 865 gsa mother board is working but not display no beep what is the problem
i thinks it's not working, check again.....
no display, no beep.....simple symptom of a dead MB
the quality of the MB is all components will work together, even if one component in it fails the MB is dead.....
this rule is not applicable to the following devices in the MB
inbuilt sound cards, or
either of the USB ports or
mouse port, keyboard port
As you can use an external device like a USB sound adaptor insted of the internal sound card for your speaker/sound.
The same goes for mouse and keyboard, you can buy keyboards/mouse that work thru USB
The same is of a USB port, if one of the USB ports fail you have the other ports to use, if all of the USB ports fail then you can use a external USB connector to a LAN port and make the LAN port a USB device.
also.....there is no option..... that you can change one of the components.....they all are embeded in the circuit board, it's cost effective to get a new MB than repair the defective component.....
all the best
Nov 18, 2010 | Intel Motherboard
31PR supports parallel port or not?
I HAVE DG31PR M/B AND ADD PIC CARD IN PRINTER PORT\r\nADD PRINTER AND PRINT IN ONLY WINDOWS BASED.
other M/b Onboard
I HAVE DOS BASED PRINT Eg. c:\dir >prn to print to directories names.
but could not print out. because printer port is LPT3 is named.
anyway i am try to lpt3 to lpt the following steps
divice manager
ports
com & lpt
lpt3- properties
port setting
port lpt3 to lpt1
apply
then print is successfully
the above setup followed in DG31PR m/b.
lpt3- properties
port setting (tab) not viewed
Why?
Jun 23, 2009 | Intel DG31PR Motherboard
PC Chips M957G MB. Can the 4 rear 4 USB ports easily be replaced?
hi there,
the rear USB port cannot be replaced, & glad that you still have a front USB connections into your MOBO..?
May i ask why did they suggest you to use the front USB panel..? Can you give us some info why this was happen..?
Thank you
May 27, 2008 | PC Chips M957G Motherboard
Athlon 2800+ XP-M runs at 606 MHz
1. Check your battery, 2. Press CTRL+F1 or ALT+F1 while you are in the BIOS. 3. Update your BIOS Microcode and CPU Code.
Sep 20, 2007 | AMD AXMJ2800FHQ4C - Athlon 2800+ XP-M...
Open Questions:
Computers & Internet Logo
101 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
