Question about Locks & Locksmithing
Hi my electronic weiser powerbolt 1000 locks but does not retract or unlock.
Posted by Henri Nadeau on
5 Related Answers
Anonymous
  • 68 Answers
SOURCE: center button unlocks insted of locks code locks insted of unlock
Take off the inside cover and move the door direction jumper over one pin.
Posted on Mar 23, 2009
Anonymous
SOURCE: Powerbolt 1000 uses up batteries in a week
Get in touch with Weiser Canada via the contact info on their web site (http://www.weiserlock.ca/wei-eng/contact.htm) for a replacement under warranty (the Powerbolt has a lifetime mechanical guarantee). i have two rental properties with Powerbolt locks on them and have found - over the past 3 years - that it's safest to just replace the batteries on a 4 month schedule to ensure the tenants don't get locked out! The batteries actually last for longer than ~ 6 months, but i prefer to be on the safe side ...
Cheers,
Posted on Jun 11, 2009
Anonymous
  • 26 Answers
SOURCE: my powerbolt keeps beeping short beeps and then
dead batteries
Posted on Aug 18, 2009
sonicboomele
sonic boom electronics
  • 1557 Answers
SOURCE: How do I reprogram the
  • Remove the inner cover plate from the lock.
  • Locate the small round reset button near the left side of the circuit board (Red or Black).
  • To program, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  • To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
best of luck.
Posted on Aug 02, 2010
Coaltowner
  • 963 Answers
SOURCE: Touch pad does not work on weiser lock powerbolt.
I found this Frequently Asked Questions sheet for the Powerbolt 1000:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
I hope this helps.
Posted on Mar 05, 2011
I guess I need to purchase a new cap that goes over the pins. Mine is missing and my door unlocks when the lock button is pushed,
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
Sep 05, 2012 | Weiser Lock Powerbolt 1000 Lock
I have a weiser lock. when i punch the buttons the motor is heard but the plastic gear isnt turning. the bolt will come out alittle sometimes and then others not. ichanged the batteries so the motor is...
If your lock has previously been working, then developed this problem, you likely have developed a mechanical problem within the lock.I recently helped someone else with a Powerbolt that would not fully extend and retract--he thought it was an electronic problem at first. Then he removed the deadbolt assembly and found, in his words, "the deadbolt is ensconced with a plastic sleeve when it retracts into the latch housing. The sleeve is shattered and most likely to be the cause of its malfunction." Something to look at!
Weiser claims to have a full lifetime warranty on mechanical parts. Contact information:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
Good luck--and please provide feedback if this helps!
Sep 19, 2011 | Weiser Lock Powerbolt 1000 Lock
I am looking for a manuals for a weiser lock powerbolt 1000 can i down lord
powerbolt 1000
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
The instructions for reprogramming the code can be found there. Good luck!!
Apr 07, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
Weiser powerbolt worked well for several months but now is not reliable anymore. Changing batteries did not help. It sounds like it is locking but sometimes fails to lock...we cannot trust it anymore
Hi... You have too be sure that the deadbolt is free when it go inside the deadbolt hole... however this system is very low power and the (over torque clutch) will sleep if the deadbolt it's not completely free.
Also if you try to open the door before you unlock it, you may block the the deadbolt inside the deadbolt hole. Take care too unlock the door before open-it...
Good lock or good unlock
Feb 05, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
The lock does not retract all the way in when you enter your code, it seems to get stuck half way so you cannot open the door???
Weiser has a one year warranty against electronic problems and a lifetime warranty for mechanical and finish problems with their locks. Contact them from this link:
http://www.weiserlock.com/en/Products/SmartSeries/Powerbolt.aspx
Nov 29, 2010 | Weiser Lock Powerbolt 1000 Lock
Weiser has a one year warranty against electronic malfunction and a lifetime warranty against mechanical and finish problems.
You can review it and contact them for further assistance from this link:
http://www.weiserlock.com/CustomerService/WarrantyInfo/Powerbolt.aspx
My bolt does net retract it sounds like it engages but it does not move i have the power bolt 1000 help?
Nov 22, 2010 | Kwikset Powerbolt/Electronic Deadbolt-...
The deadbolt will not retract. even when new battaries are installed
Does the motor run when activated? If so, your friction wheel "O"ring is worn out. This is a mechanical issue and should be covered by the Lifetime Warranty.
Call them. You only need to send the battery compartment side in. (inside of door)
Sep 20, 2010 | Weiser Lock ED1460X3VKD Powerbolt 1000...
When I enter my code the bolt only retracts 75%, leaving the door still secured.
Try pulling or pushing the door in while you lock and unlock, sounds like the bolt is binding in the door frame, comon problem with these locks in changing temperatures and humidity.
Feb 21, 2010 | Weiser Lock Powerbolt 1000 Lock
Locks & Locksmithing Logo
152 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Chris Walker
Chris Walker
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
