Question about Dragon Toys
Animated wings on my 3 headed dragon will blow up but do not move
Posted by Amalia Smith on
My tmfx 1506 One of my heads just stopped working, the other 5 heads are running fine. Need to fix
Wow! That simply "blows away" the saying, "two heads are better than one!"
Heads on what? Obviously not a living creature, unless it was a dragon in "How to Train Your Dragon!"
Maybe it's a radial aircraft engine from the 1920's. Those had a separate head for each cylinder. That was the type that had to be started by someone quickly pulling on the propeller. Is that what those six heads are on? How are the six spark plugs? Are any of them oil-fouled?
Apr 20, 2017 | Cars & Trucks
How do planes stay in sky?
You may notice that wings are usually curved at the top and fairly flat on the bottom. This causes the air over the top of the wing to move faster and therefore have a lower pressure than the air under the wing. The lower pressure mixed with the high pressure under the wing cause "lift". You can demonstrate this by holding a sheet of paper at one edge and blowing over the top of it. The paper will rise as you blow due to the low pressure you're creating by the faster air flow. It's called Bernoulli's principle.
Jan 04, 2017 | Aircrafts
My gemmy santa claus stop dancing and head moves one way
Here are 2 reasons why he would have stop dancing 1.the motor inside the body might be dead 2.a wire came off of the motor for the head could could just be the motor is dying
Jul 08, 2014 | Gemmy Life-Sized Animated Santa
With regard to the playmobil giant dragon: how do the wings attach? they will not stay in place
You have to really forcefully jamb the wings into their sockets. It's best to position/bend the limb so the swiveling hinge/anchor can be pushed directly down into the hole without exerting any force through the limb itself. As you push down and in you can at the same time be bending the limb back up as needed to get the right leverage. It's slightly harder when one wing is in and you are working on the second one but it's just a matter of positioning the other wing and maintaining proper leverage. The wings can come back out fairly easily if bent perpendicular to the hinge.
Dec 21, 2010 | Playmobil Giant Dragon
Hi I have Buck the animated trophy which I
Hi, this is a bit of a long shot but im searching for one of these and would you be interested in selling it by any chance?
Apr 29, 2010 | Toys
How do i defeat the dragon ? at the start of the level and weres the ash tray
Patty and Selma make up the heads of a two headed dragon (real surprise there)
that is reeking havoc on a village. First recruit some villagers with Marge's
mob control. Now switch to Homerball and watch the dragon. It flies and pauses
in between gaps in the bridges that make up part of the upper area. Blast across
the bridge and into the dragon to knock it to the ground. Now switch to Marge
and command the minions to attack. Repeat three times to defeat the dragon
before it destroys too many homes.
The next area is a dungeon. The Moe's will continue to attack until you destroy
the gray brick structure they are spawning from. The coffins house more
potential mob members. Continue forward and grab Marge's police hat near the
bridge. Go up the stairs to the left destroying Moe's and enemy spawn doors.
At the top is a treasure chest and a lever that opens the large door below.
Pass through the door and fight of Otto and his spawn point. Step on the buttons
to enter the overhead camera dungeon crawler portion of the game.
Move up to the large closed off area with the Moes and destroy the wall. Defeat
the Moes and grab the key. Move back around to the yellow wall and it will
disappear. Enter the hole in front of the statue. At the next part of the
dungeon turn left and go to the end of the hall. At the dead end is another
giant key. Head back down and move to the right of the screen toward the
Moes behind a wall. Destroy the wall and retrieve another key. Now move all the
way to the bottom of the area and open the last gold wall to find the exit.
Destruction of both spawn points reveals a couple of pressure plates that opens
the door. Inside are several spawn points and numerous enemies. Try to take out
of the spawn points at first. Once the enemies are gone command 4 mob members
to stand on in each of the claws of the giant dragon. This raises stairs of
gold. Take the stairs on up to the dragon's eyes. Send Maggie inside the right
eye. Press two red buttons to open the dragon's mouth. Enter the mouth and
face three phases against the dragon sisters.
During each phase of the boss fight Homer has to float up and bop Patty and
Selma on the head. Just watch the flight patterns and hover in the area where
it flys the most. In between the 2nd and 3rd wave is an egg wave. Have Homer
run through the eggs to destroy them. If any egg remains it turns into a Moe.
Aug 04, 2009 | EA - Electronic Arts The Simpsons Game
Toys Logo
131 people viewed this question
Top Dragon Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Dragon Toy Expert? Answer questions, earn points and help others
