Question about Measuring Tools & Sensors
I need to replace the wind sensor for my Lacrosse WS-1912-IT weather station due to a hailstorm tearing of 2 of the wind cups...where can I order these from and be sure the new part fits? Roger
Posted by Roger Hoff on
Tom Chichester
    Top Expert:
  • Measuring To... Master
  • 56,046 Answers
Order from LaCrosse.
Posted on Oct 01, 2019
4 Related Answers
Anonymous
SOURCE: WS-1510-iT La Crosse Wireless Weather
My 1510-IT came with a faulty battery cover top for the rain guage. There should be a metallic clip mounted to the cover to tie the 2 batteries together electrically. Mine had nothing there. I soldered a wire between the 2 batteries and used some cardboard under the cover to make sure the batteries were pushed down into their holder. Problem solved!
I can't imagine this is systemic but it happened to me.
Posted on Sep 22, 2008
  • 18403 Answers
SOURCE: Will a whc2 work in place a wh5 on a Ambient weather station WS-1285
http://www.ambientweather.com/amw23c.html
Posted on Dec 01, 2015
emissionwiz
Marvin
  • 85239 Answers
SOURCE: Lacrosse weather station model T85647
Either the sensor is defective or the receiver is, toss a coin.
Posted on Jun 30, 2017
Batteries for ws 1000 weather station
Search Results
Ambient Weather WS-1000-BATT 3 x AA Rechargeable Batteries for ...
https://www.ambientweather.com/amws1000batt.html Ambient Weather WS-1000-BATT 3 x AA Rechargeable Batteries for WS-1000-WiFi, ... Buy weather stations, wireless weather stations, emergency radios, ...
Ambient Weather WS-1000-WIFI, WS-1001-WIFI, WS-1002-WIFI ...
https://www.ambientweather.com/amwewswestre.html Buy weather stations, wireless weather stations, emergency radios, barometers, ... Ambient Weather WS-1000-BATT 3 x AA Rechargeable Batteries for ...
[PDF]Ambient Weather WS-1001-WiFi OBSERVER Solar Powered Wireless
site.ambientweatherstore.com/Manuals/ws1000wifi.pdf The WS-1000-WiFi weather station consists of a display console (receiver), an all in one sensor ... Locate the battery door on the bottom of the sensor array.
Ws 1000 weather station batteries Google Search
May 26, 2018 | Cars & Trucks
Need instruction sheet for LaCross weather station model WS-9117U-IT Hope you can help.
Try Googling (Lacrosse)(WS-9117U-IT)(manual) without parens. Note spelling of LaCrosse.
May 01, 2018 | Measuring Tools & Sensors
How do you set the time?
Page 2 of the manual (linked below) details setting time on this device.
http://www.lacrossetechnology.com/9782twc/manual.pdf
Mar 12, 2015 | Lacrosse The Weather Channel WS-9782TWC-IT...
Hi,two of the three cups on the wind sensor have broken off and i am now looking to see if the piece with the cups can be replace. will the unit record with one cup?thanksronald rosandichrrosandich1
Hello Ronald
No it won't accurately record Wind Speed because it is out of balance and lacking two parts of its motive power.
Here is a link to a new wind vane. Or you could superglue the bowl of a plastic spoon to it. Use Superglue Gel.
Please don't post personal contact details to FIXYA. We have 7 million visitors a year and some of them will try and scam you or phone you are 3:00am for a chat!
Andrew - Fixya Moderator
tx 23u wind sensor for la crosse 915 mhz weather stations eBay
lacrosse ws 2813u it wind sensor parts Google Search
Jan 21, 2018 | Lacrosse La Crosse WS-2813U-IT Pro...
My outside temperature and humidity sensor appears to have failed. I'd like to buy a replacement. 433 MHz. The system is WS-7395U. Please advise price. [email protected]
The WS-7395U uses the La Crosse TX8U outdoor temperature and humidity sensor. That part has a $49.99 MSRP. It is $46.95 from La Crosse; see http://www.lacrossetechnology.com/tx8/index.php to order the part. Other vendors that I checked do not have the sensor in stock for sale separately.
I hope this helps.
Aug 21, 2013 | La Crosse Technology La Crosse C86234...
Ws 2800 rain not displayed
I tried this and it worked fine
FACTORY RESTART:
A Factory Reset will erase the connection between the Display and the Thermo-hygro sensor and allow a fresh connection to be re-established. It is recommended to have the display and all sensors 5-10 feet apart for this restart.
ENTER PROGRAM MENU
Press and hold the SET button until you enter the program menu. Press and release the SET button until you see 'rES oFF' flashing.
FACTORY RESET ON
Use the UP ARROW key or DOWN ARROW key to turn rES on.
CONFIRM & COUNTDOWN
Press the SET key to confirm and a countdown timer will begin counting down from 127. When the timer displays dOnE, you must remove the batteries from the display for 10 minutes
REMOVE BATTERIES FROM THERMOHYGRO AND RAIN
While the batteries are out of the display, also remove the batteries from the Thermo-hygro sensor and the Rain sensor. Wait 15 minutes.
GENTLY KEY THE WIND SENSOR
Gently key the wind sensor one time to activate the sensor.
INSTALL BATTERIES INTO THERMOHYGO AND RAIN
Insert fresh alkaline batteries into the Thermohygro sensor and Rain sensor make sure to check polarity with the markings on the battery cover and inside the battery compartment. Wait 2 minutes.
INSTALL BATTERIES INTO DISPLAY: Insert fresh alkaline batteries into the Display. Make sure to check polarity with the markings inside the battery compartment
15 MINUTES: Wait 15 minutes for the outdoor weather data to display. If the outdoor data displays dashes after waiting for 15 minutes, repeat the steps of restart.
AZ Road Runner
Sep 15, 2012 | Lacrosse La Crosse WS-2800 Series Wind Cup...
The sensor from my weather station is not registering outside temperature
I've had the same problem since I bought this unit 2+ years ago; when the outside temperature moves into the freezing zone, the sensor stops transmitting. I contacted Lacrosse-- all they could suggest was change the batteries. My solution: throw it in the trash!
Aug 05, 2012 | Bushnell Measuring Tools & Sensors
Measuring Tools & Sensors Logo
128 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
