Question about Canon C2058 Color Copier
Canon irc3380i paperjam
Our canon irc3380i makes a paperjam when we print on the manual feeder. is it a problem of the feeder, or the printer itself?
Sergey Artuganov
    Guru:
  • 389 Answers
This problem fault manual presenting the track. Follows to consider several reasons. Check the condition rubber roller seizure of the paper. Check and clean lower brake platform. Check and value the possible ragged sheet of paper. Check presence a stranger subject in giving device. Try to give the paper along on format by narrow side. Thank you, good luck!
Posted on Sep 16, 2009
Testimonial: "thanks for the advice"
Anonymous
    New Friend:
Hello iam technical i have paper jam from drawer and befor heater
Posted on Jan 18, 2010
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice...
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
6128_image_6.gif Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "Manual Print Head Alignment."
Sep 10, 2014 | Canon PIXMA Office Equipment & Supplies
My IP2700 got a paper jam.I successfully removed the paper manually and the printer looks normal. Turned off and on the printer and rebooted the laptop however, whenever i tried printing, it tells me it...
Please check your paper feeder from your printer, press the paper feeder tightly and turn on the printer... don release to hold the paper feeder until the process is complete.... thanks
Aug 14, 2011 | Canon Pixma iP2700 InkJet Photo Printer
My canon mp190 gives E3 paperjam error but there is no paperjam how do i fix it?
I have solved this problem with read post at http://slayo.com/how-to-fix-error-e3-canon-mp198-printer.html thanks to slayo.com "Canon MP198 Printer Error E3 is becaused something inside of the printer that makes paper sensor not function properly. To fix this error E3 you must open inside of the printer to remove the things." you must open your printer to remove the things, maybe waste letter or other small part things. Read the post for complete it.
May 18, 2010 | Office Equipment & Supplies
Printer epson r230 paperjam
Indikator paper jam di status monitor bisa berarti benar-benar paper jam atau carriage problem. Coba dibongkar dulu printernya, mungkin ada sesuatu yang nyangkut pada paper feeder, bersihkan sekalian paper sensor pada paper feeder. Kemungkinan kedua adalah problem pada carriage atau bisa jadi pada chip di ink tank. Coba dulu ganti chip pada ink tank dengan yang lain ( yang baru atau yang arc). Salam dari Arema
Dec 29, 2009 | Epson STYLUS R230 InkJet Photo Printer
Printer keeps stating paperjam but there is no paper in it
Check the back of the printer. There should be a removable rear panel. Just Pull back on the lever (I believe on the right side) The rear panel will come off. See if any paper is lodged along the paper feeder wheels, if so, just remove it.  Also check back in the front of the printer and make sure there is none lodged along the feeder there where the paper normally comes out.
Power the printer back up and try to print again.
Hope this helps
-enov8
Mar 07, 2009 | HP Deskjet D1420 InkJet Photo Printer
Not feeding
Have you still getting the problem, have you done cleaning of Cartridge, its nozzle and Contact strip.. then cleaning of Printer roller or carriage rack.. Do a Service of it or get it done by Technician.
Also check the feeder tray.. to grab paper one by one by printer.. Manually
Take all updates for printer and OS.
Oct 31, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Paperjam in printer
1. Turn the printer off.
2. Unplug the power cord of the printer
3. Open the rear access door
4. Remove the jam
5. Clean the rollers of the printer with a lint free cloth that is moist with water
6. Close the rear access door
7. If you a document feeder open it and try to remove the paper jam and also clean the rollers
8. Close the document feeder
9. Plug the printer directly to the wall outlet
10. Try to print again
Aug 10, 2008 | HP Office Equipment & Supplies
Printer
Sometimes just a teensy bit of paper stuck inside will make it say paperjam. I would check very well.
Dec 11, 2006 | Canon I900D InkJet Photo Printer
Canon C2058 Color Copier Logo
275 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
