Question about Sharp Computers & Internet
Trying to remove old sharp carousal model R1380 microwave and replace it.
No install manual don't know how to rwmove it
    Top Expert:
  • Sharp Master
  • 66,568 Answers
GOOD LUCK THEY CAN BE A BEAR TO TEAR OUT
Posted on Nov 05, 2019
5 Suggested Answers
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: crack in the door
You can order separate panels for the door as opposed to whole door, assuming they are still available.
We have the service / repair manuals for this model and have uploaded them to our site here and here to help you.
They will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Posted on May 20, 2009
Anonymous
SOURCE: Sharp Carousel Model R-1440 won't shut off
Take it immediately to a local Microwave repair shop...looks like one of the circuits may have gone...otherwise switch off from mains
Posted on Oct 20, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Sharp Carousel Model R-1440 won't stop running
It may be a sticking door switch (upper or lower, not the middle one) or the mount of one of those switches may be loose, broken or out of alignment.
See these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you can get to the switches.
Or it may be a sticking relay on the control board. We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
If during this unwanted operation the oven lamp, internal cooling fan, and stirrer are all stuck on, but the turntable is not on moving and the oven is not actually cooking, then I would suspect relay RY1 on the control board is stuck.
That's what I suspect in your case.
Posted on Dec 13, 2009
Anonymous
SOURCE: how do i remove sharp microwave from wall model
The only problem that ricksterboy doesn't list, is there are also two screws located underneath as well. You have to take off the filter screens to find them. They secure into steel supports inside the microwave.
No getting the micro off the wall w/o removing them, or using a sledge hammer...which after all the time we used trying to get the thing off the wall, seemed like a good theraputic option.
Lucky we took off the vent cover and discovered the additional anchors.
Posted on Mar 27, 2010
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: sharp model R1380 - carousel does not work
The service manuals you need to refer to for disassembly help and proper part numbers are here and here.
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can order Sharp parts from Encompass here or call them toll-free at 866-779-5835.
Posted on Aug 22, 2010
Want to see the inside of 17.5 horsepower mower the crank shaft( how to set it)
Rwmove the three screws in the fkywheel cover and you will see the flywheel. Remove the nut and you will see that the crankshaft has a square slot as does the flywheel and this is what keeps in time.
Aug 15, 2013 | Garden
I don't have the instructions and I am looking for an online instructions manual on how to install this fan.
* I don't have the instructions
* Problem with the Vacuums
* I don't have the instructions and I am looking for an online instructions manual on how to install this fan
I guess you pressed SEND before you could say what it is, the brand name, and the model.
Can you give it another try?
It would be very nice to know if anyone can help.
Jun 27, 2011 | Vacuums
I have a raindrip 2 zone water timer...I don't know how to set it. There is no clock set, so I don't know how to program it to turn on at a certain time...
You can download your instructions here:
R673CT Digital Water Timer Installation Manual
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | Raindrip R673CT Digital Water Timer
Need to change headlight switch on dash went bad
Use a pocket screw driver - pull light switch knob out and pull back on metal retainer for knob until it releases . Remove insteument panel bezel around cluster and remove screws that retain the switch assy and rwmove switch and unplug connector- note it may be melted and hard to remove ! Once out push the button on the bottom of switch assy while pulling out rod , remove the the rod . If connector is melted obtain a pigtail connector and cut and solder a new connector in and install switch in reverse order ! Note that useing diaelectric grease in connector to switch helps with conductivity and helps block moisture !
Mar 14, 2011 | 1995 Ford F350
My nissan sunny GA15DE was overhauled but started having rough idle immediately threafter. what could have caused this? Gerald
Gerald:Was the engine overhauled because of the smoking problem? If so, the auto trans solution is more likely your problem. Good Luck
  • Automatic transmission? - Check vacuum line to transmission . The only line of rubber going to trans. Located where it attaches ro trans and rwmove it watching to see if it contains any trans fluid. If hose has oil in itm Then replace the valve it was attached to. The valve is called a transmission modulator. The diaphragm is rupture and aloowing engine vacuum to **** and burn the fluid. your trans should be needing fluid too often. Modulator around 12.00 last known.
  • Manual transmission ? - PCVvalve not bafflrd against drawing oil from its location in valve cover.and or Pcv valve is defective. Cheap fix-replace
Apr 13, 2009 | 1994 Nissan Sentra 4-Door
I don,t know how to instal this hardware,
You can find manual at ftp://ftp.dlink.com/Gateway/di714/Manual/DI-714_manual_07062005.pdf
Mar 09, 2009 | D-Link AirPlus DI-714P+ (DI714P) 802.11b
Computers & Internet Logo
19 people viewed this question
Top Sharp Computers & Internet Experts
Jason Harris
Jason Harris
Ekse
Siul Oyaratgam
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
