Probably a worn-out bearing; try rocking the empty drum by hand within the tub. If it is loose on the hub, discontinue use to avoid further serious damage, and get a service engineer to take a look.
Testimonial: "is that the direct drive motor coupleing?"
is that the direct drive coupling
You ask "is that the direct drive motor coupling?" No, it's the bearing between the tub and the drum.
is it worth repairing?
you realize it is still working great it is just at the end of the major spin
"Is it worth repairing?" -a service engineer will give you an idea of repair cost, and the decision will be yours. There are numerous other possible causes for the noise (such as the drive coupling that you mention or the drive block or loose mountings) which would be worth fixing. I'm concerned that continuing to use the machine may cause a more serious failure, so I recommend you get someone to inspect it and give you an estimate. There's a very useful website called partselect.com where you can see diagnostics and the repair parts, where to fit them and how much they cost.
y's friend makes $96 hourly on the internet. She has been with out artwork for five months however final month her charge emerge as $12747 really on foot on the internet for some hours. study greater on this net internet site.....https://www.hit2day.com
SOURCE: Kenmore 90 series noise after spin
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
SOURCE: Loud rumble
sounds like a classic unbalanced footer issue...that can happen after a time, you know.
get a level, and check that first..
SOURCE: kenmore washer 90 series Washer will not spin
SOURCE: Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
