Question about Lenovo 3000 N200 Notebook
3000 N200 0769 model.. XP and dual-core sleep mode is not activated in the shutdown window. tried getting into advance in power option still not activated Please guide
Posted by fahanas on
Anonymous
    Problem Solver:
  • 6 Answers
Not capable of sleep mode, some units just dont have that feature available.
Posted on Sep 16, 2009
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
My lenovo g450 shuts down when the lid closes
Try this:
Windows 7
  • 7
    Click "Start," and then select "Control Panel."
  • 8
    Double-click "Power Options."
  • 9
    Select "High Performance" under "Additional Plans," and then click "Change Plan Settings." Change all of the options to say "Never."
Im running a external MONITOR. How can keep windows running when I shut the lid to my laptop? thanks
Windows XP:
By default, all laptops either go on standby or turn off to save precious battery, but you can override these rules from the Power Options (XP) in your control panel (Start > Control Panel > Performance and Maintenance > Power Options) and click on Advanced Tab and override the settings according to your preference.
I prefer "Do nothing" while closing the lid. Although this is real simple, few of us might not know it. I
Windows Vista/7:
How to Stop Laptop/Notebook Goes To Sleep or Hibernation when Closing Lid in Windows Vista
  1. Log on to your computer as an administrator. Click on Start, go to Control Panel -> System and Maintenance -> Power Options.
  2. Click on Change plan settings for the currently active plan.
  3. Click on Change advanced power settings link.
  4. In the "Power Options" dialog box's "Advanced Settings" tab for the active power plan, expand Power buttons and lid.
  5. Expand Lid close action.
  6. Change the value to Do nothing for "Lid close action" by selecting a new option from drop down menu for both On battery and Plugged in. do-nothing-lid-close-281x300.jpg Based on own preference, it's possible to set other action from the menu too. Available for selection is Do nothing, Sleep, Hibernate and Shutdown.
  7. Click OK button.
Why my lenovo b450 laptop shutdown when in sleep modeif I'm not using it for about 10 minutes?
hi! just a tip! you could actually adjust the settings on that so that it wouldnt sleep after 10 minutes. you could adjust the settings of it on the lenovo energy management or on the power management. try to adjust the hibernation on it and the sleeping time as well. hope this helps! goodluck!
My laptop is going on sleeping mode.
Hello try to check the power setting of your laptop.
If your using Windows systems kindly follow below:
1. Goto Display Properties by right clicking the blank screen of your main
menu. Then click Property.
2. Then when Dispaly Property is pop up go to tab Screen Saver then Click
Power Button below.
3. Within the Power Option Properties kindly check the configuration of
the following:
a. Power Schemes
b. Alarms
c. Power Meter
d. Advance
reconfigure all of the tabs above and change its configuration in your own custom setting.
Need more assistance please reply to this post.
Thank you.
XP safe mode problems
you could try editing the boot.ini to switch the vista install and xp install.
try this
http://news.softpedia.com/news/Windows-XP-Fails-to-Start-After-You-Install-Vista-In-Dual-boot-Configuration-47906.shtml
ITunes will not play songs on my Logitech speakers
you can disable the sleep mode when you close the lid.
for windows xp
  1. Click Start, and then click Control Panel.
  2. Click Performance and Maintenance.
  3. Click Power Options.
  4. Click Advanced tab.
  5. Under “Power buttons” section, select Do nothing from drop down menu for When I close the lid on my portable computer option.
for windows vista
  1. Click on Start, go to Control Panel -> System and Maintenance -> Power Options.
  4. In the “Power Options” dialog box’s “Advanced Settings” tab for the active power plan, expand Power buttons and lid.
  6. Change the value to Do nothing for “Lid close action” by selecting a new option from drop down menu for both On battery and Plugged in.
Laptop switches of after 5 minutes when on ac power irrespective of power up mode
You may try to uncheck the box under my computer>right click> properties> advanced> startup and recovery.
uncheck the box for automatic restart.
try to blow a can of compressed air into your fan and heat sink channel.
then try to run windows update or go to update.microsoft.com to do so..
regards,
Ronald.
Lenovo 3000 N200 Notebook Logo
Top Lenovo Computers & Internet Experts
Ekse
Abhinandan  Patil
Abhinandan Patil
Steve Sweetleaf
Steve Sweetleaf
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
