Question about Jenn-Air JCD2389G Side by Side Refrigerator
Motor is running but it is not cold fride and freezer are 60deg
Came home to find water from the freezer for my freezer and fridge had quit working, light is on and it is running and turned all the way up... any ideas. Well I guess there is more as I was typing this my son called me into the kitchen for the fridge was making strange sounds and smelled like it was burning up. So I unplugged it! Now that is dangerous!
Posted by melani502004 on
Terence Fourie
  • 909 Answers
Sounds to me like the compressor has become faulty. it is not able to start. After a while the clixon starts to burn which explains that smell. Suggest replacement.
Posted on Sep 16, 2009
My ge profile PFS22SISBSS FRIDE IS NOT STAYING COOL WHAT COULD BE THE PROBLEM?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 21, 2010 | GE Profile PFS22SBSS Bottom Freezer French...
I've had this problem before, where the fan is frozen so the fridge is no longer cold but the freeze is OK. What the guy did last time was remove the floor of the fridge, and poured hot water on the fan...
fridge not going into defrost, freezing up coil, replace defrost control, should thaw out fridge, or your evaporator fan motor is burnd out, thaw fride first see if fan works, if fan ok ,derost timer, if not relace fan motor
Sep 06, 2010 | GE GDS20KBS Bottom Freezer Refrigerator
GE refrigerator is not working. the lights are on in the inside of fride and freezer but the fridge isn't running. My external digital temperature controls, water dispenser, ice cube dispenser, is not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
qrtgfs
Jun 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refigerator is not cooling below 60deg, it is set at 44. The freezer works perfect (-2). the condenser had not been cleaned in a couple of years. I vacuumed it then used EasyOff oven cleaner on the...
sounds like your fan (in the freezer) has quit working. This fan is supposed to send cold air from the freezer to the refrigerator.
check and see if it's running.
hope this helps
Jun 14, 2010 | Sub-Zero 650 / O Bottom Freezer...
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fride not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Aug 04, 2009 | Amana ARB9059CS Bottom Freezer...
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Jenn-Air JCD2389G Side by Side Refrigerator Logo
152 people viewed this question
Top Jenn-Air Refrigerators Experts
john h
Sheldon Dedek
Marvin
Marvin
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
