SOURCE: Chainsaw runs, but dies when given gas.
adjust the gas and air on the two little screws on the carborator
SOURCE: my homelite super 2 chainsaw keeps flooding. it
Needle valve in carb. maybe hung open. Or diaphragm may be bad. You will need to remove carb. and clean and replace all worn parts. Go to homelite.com to find manual for the saw.
SOURCE: chainsaw starts and runs fine for a few minutes
Try fresh fuel making sure oil and gas mixture is correct. Carb might need cleaning and adjustment.
SOURCE: Chainsaw runs but when I start cutting it dies
you might just neet to clean the air filter and/or the carb.
SOURCE: poulan wood shark 1950 wont start spark plug has
Try to squirt a little gas in the carb and see if it pops or tries to run for a short time. The diaphram in the carb is probably old and hard. That would be the first place I would look.
