Question about LG Cell Phones
When straight talk lg stylo 2 comes on it only shows the lg logo and says securiuty error authentication fail #9 how do i fix this
Posted by tammy tammy on
5 Related Answers
ginko
Ginko
  • 19396 Answers
SOURCE: My Lg Monitor wont show screen (Power Button Flashing)
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 04, 2009
selva6969
  • 124 Answers
SOURCE: LG Rumor 2 won't get past the lg logo on startup
this is a software problem !!! change the software fo your mobile in the nearest outlet
Posted on Jul 17, 2009
alexalexutzu
SOURCE: help!!my cookie just shows LG logo!!
I have the KP501, too. Well, as I know, there is no difference between KP500 and KP501...it's the same OS...My Cookie doesn't want to turn on. When I try to turn on the phone it shows just the LG logo, more not. A few seconds later it turns automatically off and than 3 seconds later it turns on again....I don't know how is this happening...searching for help!!! please help me.... :S
Posted on Aug 07, 2009
Anonymous
  • 23 Answers
SOURCE: user admin failed to login (wrong authentication)
The error means that the user name or password entered is wrong. The way to recover your router is by reseting it to factory defaults see details in: http://www.sofaware.com/uploadFiles/77500552.pdf
Please note before reseting to factory defaults that you will have to reconfigure the router from scratch and technical assistance might be required.
Posted on Nov 25, 2009
Anonymous
SOURCE: I have an LG 220C with Straight Talk. How does
go to settings-security-enter the code(last 4 digits of number)- restrictions-data-unlock- and it should work.
Posted on Jan 22, 2010
Lg stylo 2 user guide
Google (LG)(stylo 2)(manual) without parens.
Aug 14, 2018 | LG Cell Phones
Lg stylo 3 m430 cricket wirles
If you could just edit this and craft it into a question please.
LG Stylo 3 Smartphone with Stylus Pen for Cricket (M430) Titan | LG ...
https://www.lg.com › Home › All Phones › LG M430 Titan Gray
Get information on the LG Stylo™ 3 Smartphone with Stylus Pen (M430) in Titan for Cricket Wireless. Find product images, reviews and tech specs for this ...
LG Help Library: LG CRICKET STYLO 3 M430 SOFTWARE UPDATE ...
https://www.lg.com › Home › Support › Product Help › Help Library
May 17, 2018 - LG Help Library: LG CRICKET STYLO 3 M430 SOFTWARE UPDATE. Learn about product installation, maintenance, and troubleshooting using ...
Lg stylo 3 m430 cricket | Android Development and Hacking - XDA ...
https://forum.xda-developers.com/android/general/lg-stylo-3-m430-cricket-t3614677
May 31, 2017 - 11 posts - ‎3 authors
Isnt any threads on this device. Figured Id start one. At first glances. No root. Oem u lock is in dev options. No fastboot does have dl mode.
Need root method for Cricket LG Stylo 3 (LG-M430)
Feb. 13, 2018
Cricket m430 hidden menu dialer code | Android ...
Jun. 4, 2017
More results from forum.xda-developers.com
Jul 25, 2018 | LG Cell Phones
Bypass frp on lg stylo
Go to YouTube type in search bar of stylo bypass google account a few videos will show you how bypass google account
Feb 14, 2018 | LG Cell Phones
How do I turn off the talk back feature on lg tribute
TalkBack won't turn off - Google Product Forums
productforums.google.com/d/topic/nexus/av7djMHBA14
Google
Oct 23, 2013 - 100+ posts - ‎100+ authors
Re: TalkBack won't turn off, Nexus 5 -curious user, 2/15/14 6:38 AM ... I don't blame Google for making this feature so difficult to shut off once ...
How to Disable Talk Back Mode? « Android Gadget Hacks
android.wonderhowto.com/forum/disable-talk-back-mode-0147617/
Jun 24, 2013 - If you just have the regular swipe to unlock feature for your lock screen, to unlock it ... Now, to disable TalkBack mode, you need to make your way to ... I only turned on because my lady friend has an LG Stylo G and she set her ...
How to Exit 0r Disable "TalkBack" Mode on LG Optimus F6 ...
? 3:11
https://www.youtube.com/watch?v=YDmcLi9kF8w
Dec 3, 2014 - Uploaded by Klavdio-Leadership
This Video will show you how to disable the TalkBack Mode on your phone.
LG L70 how to Turn off the talkback or voice over - YouTube
? 2:29
https://www.youtube.com/watch?v=FEei11i4OGg
Jan 13, 2016 | LG Tribute 4G No-Contract Cell Phone
Fix for internal storage on a lg g stylo from cricket
Troubleshoot issues related to low internal memory on your ...
support.sprint.com/.../Troubleshoot...internal-memory...
Sprint CorporationThis article helps you troubleshoot low internal memory issues on your LG G Stylo. You may have low internal memory issues if your phone is: Displaying low ...
Internal storage (ROM): LG G Stylo ' T-Mobile Support
https://support.t-mobile.com/docs/DOC-21750
T?Mobile US, Inc.Apr 6, 2015 - Learn how to view free space and free up storage on the LG G Stylo. Go to: Manage storage View free storage space Manage storage To ...
[PDF]User Guide (English) - Cricket
https://www.cricketwireless.com/.../lg-g-stylo/Cricket_LG_G_Stylo_User...
Jan 05, 2016 | LG Cell Phones
Will a LG4 case fit a LG G Stylo phone?
Amazon.com: Questions And Answers: Does lg4 cases fit lg g stylo ...
www.amazon.com/Does-cases-fit-stylo-phones/.../1?_...
Amazon.com, Inc.Sep 5, 2015 - Probably not. The case is fitted perfectly to the G4's curved body. It would not fit on the G2 or the G3 either. Amazon Customer answered on ...
LG G Stylo Case Cover Accessories LG Stylus LS770 Case
Jan 01, 2016 | LG Cell Phones
My metro pcs lg g stylo gives me an er081 wont let me connect to wireless calling help
Anyone else getting Error : ER081 "Unable to Connect" Wifi ...
https://www.reddit.com/.../LGG3/.../anyone_else_getting_error_er...
RedditApr 15, 2015 - Discussion of LG's 2014 flagship smartphone, the LG G3 ... Anyone else getting Error : ER081 "Unable to Connect" Wifi Calling ... permalink; save; give gold ...My phone decides to say 'No Service' on my lockscreen all the time ... Flipping airplane mode on and off forces it to try again and it connects for me.
My metro pcs lg g stylo gives me an er081 wont let ... - Fixya
www.fixya.com/.../t26022133-metro_pcs_lg_g_stylo_gives_me_er081_...
3 hours ago - When My Phone Did That, I Took It Into Metro And They Sent It In A Replaced It With A New One, The Guy At Th e counter Said That This Is A ...
Metro Pcs WiFI Calling fix 911 error - YouTube
Dec 25, 2015 | LG Cell Phones
Need apn settings for at&t straight talk Samsung galaxy discover.model sgh730g at&t4.0.1.1 when first got phone it showed. 4g.phone it blacked out called straight talk they had me changed the apn settings...
Straight Talk AT&T APN Name ATT 4G LTE APN tfdata Proxy proxy.mobile.att.net Port Username Password Server MMSC http://mmsc.mobile.att.net MMS Proxy proxy.mobile.att.net MMS Port MCC MNC Authentication Type PAP APN Type default,mms,supl,hipri APN Protocol IPv4
Sep 11, 2017 | Cell Phones
Cell Phones Logo
66 people viewed this question
Top LG Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
William Norris
William Norris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
