Question about Maytag Washing Machines
Bravos. Why a constant UL error? - Maytag Washing Machines
Posted by Kathy Harski Brookes on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: maytag bravos top load washer error code F1
Well, you're not gonna like this, but here's the deal.
Remove the three screws on the rear of the control panel and lift it up. Disconnect the rubber hose on the right side of the gray control module and blow through it to make sure it is clear and not kinked. If this check is fine then your control module needs replaced.
Note that Maytag knows this is a fairly common problem. My washer failed 9 months out of warranty with this problem.
The only good news is that it is an easy, though expensive, replacement.
Posted on Sep 25, 2009
Anonymous
SOURCE: what does the UL mean on my bravo washer.
It means unbalanced load. It causes the stub to knock against the wall and i fear it will tear up my machine. I don't know where atraild85 got his information,
Posted on Jul 06, 2010
Anonymous
  • 4 Answers
SOURCE: How reset clean washer reminder on Bravos washer
This is just a factory setting that reminds you to clean the washer to avoid that musty smell. You can buy tablets called Affresh or other similar cleaners for washing machines. They sell these items at Target, Walmart, Lowes and Home Depot. You can also substitue 1 Cup of Bleach in the washer. Then once you add whatever solution you have decided to clean it with you simply select the wash cycle on the machine called "Clean Washer with Affresh" Once you have done this the light should go out. You can also reset this indicator light by pushing the button next to the light that says Reset clean washer reminder. Hope this helps!! :)
Posted on Aug 11, 2010
richroth
Richard Roth
  • 9472 Answers
SOURCE: My maytag clothes washer Bravo quiet series 300,
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing?
This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
Is "Sd" displayed and the wash cycle dial is not flashing?
If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
Is the drain hose kinked or clogged?
Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Posted on Dec 27, 2010
Anonymous
SOURCE: My washer is constantly off
I have the same problem. I just took the back off and I can see that there is a sock lodged between the tub and the liner. Now if I can just figure out how to get to it!
Posted on Jan 11, 2011
UL bravo error code
Unbalanced load? Don't over stuff the washer. The load sensing moves the drum back and forth at the start. If it can't balance the load it will err.
Oct 16, 2013 | Maytag Bravos MTW6600T Top Load Washer
UL light keeps coming on stops spinning
The uL error code is displayed when the electronic control detects an off balance load. This can be caused by overloading, bad bearings in the tub, something between the tub and basket, or an issue with the electronics.
Feb 03, 2013 | Maytag Bravos MTW6600T Top Load Washer
MTW6600TB1 code U L
Hello. The UL code means the washer is unbalanced. Try taking out clothing around the middle and readjusting to the edges. That should help take off the code. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Jun 28, 2012 | Maytag Bravos MTW6600T Top Load Washer
OL error code
Hi jbrundage1. I believe you have a UL error code on the washer. It means that the sensors in the washer are sensing the unit is unbalanced. When the washer is empty, set it to a spin or rinse and spin setting. Run the washer through the cycle empty, as it will help to remove any excess water in the tub. Also, make sure the washer is level, as it is balanced on springs, and that could be throwing the sensors off. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Jun 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
My washer is constantly off balance with a UL error.
Jan 10, 2011 | Maytag Bravos MTW6600T Top Load Washer
My Maytag flash F 51 and ul error
Unbalanced load, open lid and redistribute the load, close lid and press START/PAUSE.
Oct 19, 2009 | Maytag Bravos MTW6600T Top Load Washer
Washing Machines Logo
78 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
