Question about Cameras
Does my Coolpix L100 have a setting for 300 DPI
Posted by judith turrentine on
5 Related Answers
Anonymous
  • 78 Answers
SOURCE: 300 dpi
Shooting pictures in Fine quality will give you atleast 300 DPI resolution. Check your camera setup menu to see what quality you're shooting in, and adjust as necessary.
If you need to print 300dpi, this is done in whatever program you're using to output. In Photoshop, this is done by going to image>image size and changing Resolution to 300 (or whatever other resolution you want)
Posted on Apr 08, 2008
welsberr
Wesley Elsberry
  • 25 Answers
SOURCE: Creating a 300 dpi x 300 dpi file
You need to be able to change the DPI setting in the image file. This can be done in most complete photo editors, though they tend to name the procedure in different ways. In Corel Photo-Paint, you would look for "Resample Image". In the open source photo editor Gimp, look for "Scale" under "Image".
In all such procedures, what you want is to set both the vertical and horizontal DPI values to 300, apply them, then save the image. Please do save it to a different filename, since you lose some quality of JPEG images every time they are saved.
Posted on Sep 25, 2008
WeNDoR
  • 4 Answers
SOURCE: i am taking pictures at
it'se easy to do :) just shoot them in RAW mode ... they will be 10 MPIX and with 300 DPI :D
Posted on Dec 01, 2008
Anonymous
  • 300 Answers
SOURCE: How do I change resolution On Fuji S700 Fine Pix??
Hi!
If I remember it right, the resolution setting were under F button on the back panel, on the right from the Playback button.
Please, let me know if I'm right. :)
Tom
Posted on Jul 30, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: How do i set the output resolution to 600 x 600 dpi on a canon mp
Hi
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/Canon-PIXMA-MP600-Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Posted on Mar 05, 2010
I have used last 4 year canon 2900B printer. How to set 300 dpi printing resoluation
Canon PIXMA Manuals MG2900 series Resolution
Resolution The data in the image you have scanned is a collection of dots carrying information about brightness and color. The density of these dots is called "resolution", and resolution will determine the amount of detail your image contains. The unit of resolution is dots per inch (dpi). Dpi is the number of dots per inch (2.5 cm). The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail.
How to Set the Resolution You can set the resolution in Resolution on the (Scanning from a Computer) tab of the Settings dialog.
Appropriate Resolution Settings Set the resolution according to the use of the scanned image.
Item Type Use Color Mode Appropriate Resolution Color photo Copying
(Printing) Color 300 dpi Creating a postcard Color 300 dpi Saving to a computer Color 300 dpi Using on a website or attaching to e-mail Color 150 dpi Black and white photo Saving to a computer Grayscale 300 dpi Using on a website or attaching to e-mail Grayscale 150 dpi Text document (document or magazine) Copying Color, Grayscale, or Black and White 300 dpi Attaching to e-mail Color, Grayscale, or Black and White 150 dpi Scanning text using OCR Color or Grayscale 300 dpi Important
  • If you double the resolution, the data size of the scanned image quadruples. If the file is too large, the processing speed will slow down significantly, and you will experience inconvenience such as lack of memory. Set the minimum required resolution according to the use of the image.
Note
  • When you will be printing the scanned image by enlarging it, scan by setting a higher resolution than the recommended one above.
300 dpi nikon coolpix s51
DPI (dots per inch) is an output parameter and has absolutely no meaning to the camera. It has meaning only when you output the photo to a printer or screen.
Let's say you took a photo that's 3000 pixels on the long side. If you then make a 4x6 print, you're putting 3000 pixels into six inches so you're printing at 500 dpi. If you make an 8x10 print, you're putting 3000 pixels into ten inches so you're printing at 300 dpi. Either way, you're printing the exact same picture, only at different dpi settings.
The camera has to put something into the dpi field, so it defaults to 72 which is often used for computer screens. Just about any program you use to print your photos can change this number without affecting anything else.
3answers
300 dpi print
go to the cannon website and check their support/downloads
Cant find the installation disc for my Nikon Coolpix L100, where can i download the software?
Try http://www.nikonusa.com/en/Nikon-Products/Product-Archive/Compact-Digital-Cameras/26170/COOLPIX-L100.html
1helpful
Where is the Black and white mode in Nikon Coolpix L100 camera?
There is no black and white mode in a Nikon Coolpix L100 camera. You can take a picture and then convert it into black an white through any photo editing software like Adobe Photoshop.
My Coolpix nikon l100 takes fuzzy videos anything I can do?
Make sure the dial on top of your camera is set to AUTO instead of Macro.
How to adjust the resolution to 300 DPI on an
If you are scanning, you should be able to set the resolution (DPI x DPI) in the scanner configuration. If it is blurry, it could be that the default scan resolution is lower (10 dpi or even 75 dpi).
Settings location will depend on the scanner and software used.
Best scan at an equal (300 dpi) or even higher resolution, so you can scale the image afterwards without quality loss.
5helpful
Change 72 dpi to 300 dpi
Your camera cannont shoot at either 72 dpi or 300 dpi. It shoots at whatever resolution you have it set for. Dpi (dots per inch) is a print specification, denoting how large (or small) your pictures are printed.
The DSC-W100's highest resolution is 3264x2448. Printed at 72 dpi, it can generate a print bigger than 40x30 inches, albeit a bit grainy. Printed at 300 dpi, you can generate 10x8 inch prints.
Again, dpi is a measure of how you print pictures. It has no bearing on how you capture images with your camera.
How can i slow the shutter speed on my Nikon Coolpix L100
technically you cant, the l100 is an all automatic camera, meaning you cant manually set the ISO, aperture, or shutter speed... a good way to slow the shutterspeed would be to autofocus on something similar but darker, then keep that focus for the origonal shot...
1helpful
300 dpi priting
Your printer doesn't have a 300 DPI setting, however, you can select "EconoMode" from the "Preferences" menu after you select "Print". Look for a tab that says "Quality". EconoMode will be lighter than normal 600 DPI printing, thereby saving toner.
Cameras Logo
Top Cameras Experts
Ekse
ADMIN Canada
ADMIN Canada
Are you a Camera Expert? Answer questions, earn points and help others
