Question about Makita Saws
Makita 51/2 inch circular saw, model 5005ba i need a wiring diagram for the switch/trigger i have the 6 prong switch.
3 wires from the cord, and five wires from the saw, what wires don't go to the trigger?
Posted by mccomb48 on
Richard Ranney
    New Friend:
  • 25 Answers
Opposite side of trigger white on top black on bottom
Posted on Nov 20, 2019
5 Related Answers
Anonymous
  • 313 Answers
SOURCE: Switch diagram
as u notice the terminal on the switch has 2 connection like a switch diagram to it.it has normally open & normally close contact. the normally close contact are for red & white wire & the other
contact are for 2 black wire which is normally open contact.hope it helps.
Posted on Sep 19, 2008
rowdy45176
David Ford
  • 2176 Answers
SOURCE: wiring diagram for makita 6510 LVR drill
I can't find the wiring schematic online but if you can bear with me I will make some phone calls thurs. and get one faxed to me. It has been so long since I had one apart that I can't remember.
Posted on Feb 11, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: i need a wiring diagram for a milwaukee heav duty circular saw
It is probably something like a 6365 and on all the Milwaukee products they have a switch wiring diagram but nothing for the switch. I would recommend going to a local repair center with the switch and match it up with a new one probably less than 15.00 If you give me your location with zip code I can direct you to the closest one. Let me know
Posted on Apr 14, 2009
Anonymous
  • 25 Answers
SOURCE: dewalt power saw wiring diagram for trigger switch
The Switching should go like this
(single letters denote wire color)
Y---o o---R
B---o o---B
The contacts where the black wires attach are the points on the switch that break when continuity is checked.
Posted on Apr 18, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: I need a diagram of the trigger wiring in my bissell proheat 8930
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sgsgff
Posted on Sep 30, 2010
2answers
Brushes arcing
Brushes arc for several reasons. If the spring over heated and lost its tension or the copper line from the brush to the cap broke/burnt off or the brush wore down too far to be pressed on the armature properly. The replacement brushes you need are Makita part number CB-124. If you still have exessive sparking after replacing the brushes you may have a bad commutator on the armature. The only way to fix that is to replace the armature, Makita part number 512831-0.
2helpful
Wiring diagram for switch on makita mlt100 saw
ring Makita on 01908 210710 and ask for technical
May 30, 2012 • Makita Saws
No power when i squeeze the trigger on the hd77
Troubleshoot the problem. It could only be a few things: 1) defective trigger/switch, in which case you can replace it by getting the part from a specialty tool store; 2) the cord itself, either where it plugs into the saw or at the plug end there may be a loose wire; 3) you've accidentally cut or nicked the cord--easily done--and there is a severed wire.
1helpful
Need wiring diagram to check continuity on trigger switchfor makita 2400b
If you cannot find wireing diagram,just have the saw unplugged and take one of the wires connected to the trigger off. Then by useing an ohm meter you can check for continuity.
1helpful
Cord replacement on skill saw model # 5007nb
the cord set you need is 664463-0, the wire guage is 2x14x8 SJ any repair shop should be able to help you with the proper wire guage cord for this tool. The installation is really easy after removing the handle half
2helpful
Circular saw motor wiring diagram
I need the wiring diagram where the they on the switch and saftey switch Where the white, black and red wires go on the red trigger switch
Saws Logo
Top Makita Saws Experts
ray gallant
Parson's Repair...
Parson's Repair...
Are you a Makita Saw Expert? Answer questions, earn points and help others
