Question about Bialetti Mukka Express
My mukka is shooting steam out of the small valve/washer thing on the bottom pot part. As it gets hots the valve pops up (but not with gusto like it used to do) and then I get a little coffee mixed in with the milk and steam shooting out the side valve. It seems like it is not building up enough pressure to push the coffee up into the top and there is no foam due to the steam loss about the side. Any ideas?
Posted by getshark on
Anonymous
    New Friend:
The safety valve on the lower boiler chamber is there to release pressue in case too much prssure builds up in the pot when brewing. If youy have an 11 mm wrench you can take it out and clean it by pulling on the outsidepart, there is a little knob that may be grabbed by a tweezer, gently pull it out, it is spring tensioned, and run water in the opposite end, Chances are some coffee grounds particles got in it and it is not seating good. after cleaning put a few drops of olive oil in it , the inside part. Should seal better and still funtion as a safety valve. Or you can leave it in place in the pot and just pull on the outside , flush with water and then put a few drops of olive oil in it. While you are at it, put olive oul on the threads, olive oil film and the the rubber seal and add a little to the rubber button on the top valve.
Posted on Jul 10, 2011
Ned C Cook
    President:
  • 3,433 Answers
There is a restriction and those valves are safeties to prevent excess steam pressure that can both injur and ruin the machine. If you can, chk all the passages for any blockage. and free movement of any valves. Good Luck,Ned-
Posted on Sep 16, 2009
1 Related Answer
Koral Ilgun
  • 3 Answers
SOURCE: My mukka is shooting steam out of the small
I had the same problem and saw this solution in another bialetti mukka problem report, which made sense: "the safety valve on the lower boiler chamber is there to release pressue in case too much prssure builds up in the pot when brewing. If youy have an 11 mm wrench you can take it out and clean it by pulling on the outsidepart, there is a little knob that may be grabbed by a tweezer, gently pull it out, it is spring tensioned, and run water in the opposite end, Chances are some coffee grounds particles got in it and it is not seating good. after cleaning put a few drops of olive oil in it , the inside part. Should seal better and still funtion as a safety valve. Or you can leave it in place in the pot and just pull on the outside , flush with water and then put a few drops of olive oil in it. While you are at it, put olive oul on the threads, olive oil film and the the rubber seal and add a little to the rubber button on the top valve."
Posted on Aug 05, 2011
Having trouble baking bread in steam oven.AegBS730470MM How do i know how much water is left to make steam?
I'm no pro, but it sounds too dry in there to me. I don't know anything about your steam oven, but I bake sour dough in a cast iron crock pot with a lid, that keeps the steam from escaping and the bread from drying out. I take the lid off the pot for the last 20 minutes to cook up the crust a bit. (I have the pot in the oven when I preheat it, so it's nice and hot when I put the dough in).
Some people put ice cubes in a small tray in the bottom of the oven to keep the moisture in there. I have tried it (once) and it seemed to work fine.
Sorry I can't help with the steam oven though.
Water shoots out of steam valve and can't make espresso
Samantha,
The steam function and the expresso use the same elements to create the steam but the valves will direct the steam to the expresso unit or the steam arm. Most likely you have a faulty valve. In most cases the valve will not open until the pressure gets to the right level. If you are just getting hot water out of the steam arm instead of steam via the expresso unit it most likely means that the valve is faulty. The valves can be replaced but is not easy. You will need to have the unit serviced or you could try to replace the valves. Make sure the flow meter is working before you replace the valves. You can check the operation of the flow meter by running the hot water cycle and making sure that you get the right amount of hot water. Good luck!
1helpful
2answers
The pressure valve on my Mukka Express doesn't pop up. Instead after 10 minutes the valve is forced off. I rinse it really well and have even put it in boiling water. How do I get it to pop up?
I have the same problem. I cleaned all the parts, changed the pressure valve, cleaned the gasket, filters, everything. I hear the steam escaping from the overflow valve and if at that point I manually pull the valve up, then it does (barely) pop and steam the milk, but not as well as it used to.
1helpful
My mukka is shooting steam out of the small valve/washer thing on the bottom pot part. As it gets hots the valve pops up (but not with gusto like it used to do) and then I get a little coffee mixed in with...
I cannot unscrew the top of the Mukka Express machine from the bottom!
If the bottom is screwed too tight on the top, you could try to warm the with hot water and cool the bottom with cold. This could help to expand the top and make it easier to unscrew.
Honda GVC 160 lost pressure - noticed small black valve (back - rear) after pressure builds up , short spray then nothing - hot water comes shooting out the black valve - did something pop off?
The small black valve is called a thermal relief valve. If it is open you will have no pressure. If the water is getting hot enough to pop that valve, there might be internal problems with the pump.
7helpful
Bialetti mukka express
First off, the best milk for foam is skim milk (0% fat). The higher the fat content, the less foamy your foam will be.
The foam is created by the steam/hot coffee from the lower part being forced through the doohickey and into the milk. That means that if the coffee itself isn't "perfect", the foam won't be "perfect". I've found that using different types of coffee (e.g. different grinds) or filling the coffee bin to different levels results in more or less steam/pressure being passed through, so the foam is better/worse. For example, if I put too much ground coffee in the bin or use too fine a grind, it blocks the water/steam that's going through the coffee, resulting in less coffee and weaker coffee, and also resulting in less foam.
1helpful
My chest type freezer ice up around the top but does not freeze except in the bottom portion
Check the gasket. Sounds like you have a leak somewhere causing the ice formations on the bottom. Easy way to check this is to have a steamer or a small pot of boiling water (steaming hot) while the frezzer is runing hold the pot of steaming water and watch the steam. You will see the steam going into the frezzer. BINGO leaking gasket. May need to replace the gasket or may beable to fix. You will see and know what to do. Keep me posted. Good luck.
Espresso irregularly spurts out the center post
could it be that the gasket is oversized and it covers the small holes ?
1helpful
Mukka Express spits out coffe from the screw section & steam valv
it did that to me too, so I reduced the amount of milk to the indicated level inside. No more mess after that.
Bialetti Mukka Express Logo
Top Bialetti Coffee Makers & Espresso Machines Experts
Pierre Laplante
Kolbrun...
Ross Keen
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
