Shellexecuteex failed code : 1060 please solve it windows 8
Posted by Kulvir Merai on
4 Related Answers
Anonymous
  • 66 Answers
SOURCE: My windows cannot open exefile and I cannot install spybotsd162.
This is possible if the Windows installer in corrupte you can try below steps -
Install Issues.
1. check the task manager for msiexec.exe processes and cancel all of them.
2. attempt to download and install MSICUU2.exe from the
http://www.microsoft.com/downloads.
3. If install is not successful on a Non-SP2 Windows XP system perform the
following:
a. search for and rename the files MSI.DLL, MSIHND.DLL, and MSIEXEC.EXE from
the %system
root%\system32 folder.
b. go to http://www.microsoft.com/downloads and download either the Windows
Installer 2.0 or 3.0
or 3.1 if this is pre-SP2 Windows XP.
4. If the install is not successful on Windows XP with SP2 try reinstalling Windows
XP SP2 from http://www.microsoft.com/downloads Keywords: SP2 and Professionals or
find the above listed files and reinstall Windows Installer v3.1
5. then attempt to reinstall the software in question
or do clean boot and try to install the software
Step 1: Start the System Configuration Utility loadTOCNode(3, 'resolution');
  1. Click Start, click Run, type msconfig, and then click OK.
  2. The System Configuration Utility dialog box is displayed
Step 2: Configure selective startup options loadTOCNode(3, 'resolution');
  1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
  2. Click to clear the Load Startup Items check box. Verify that Load System Services and Use Original BOOT.INI are checked.
  3. Click the Services tab.
  4. Click to select the Hide All Microsoft Services check box.
  5. Click Disable All, and then click OK.
  6. When you are prompted, click Restart to restart the computer
try to reinstall the soft ware .
Thank you
Posted on Mar 20, 2009
club98dj
  • 163 Answers
SOURCE: ShellExecuteEx failed; code 255
Hi,what operating system are you running?..windows xp,vista,etc
Posted on Feb 22, 2011
damneddle
damneddle
  • 1607 Answers
SOURCE: When i try to install
Update your windows then try to install the game again.
To update windows, click start menu button, all programs, then choose windows update. Download and install all important updates.
Thanks for using Fixya!
Posted on Jun 03, 2011
White Zombie
  • 4961 Answers
SOURCE: When i try to install a program. ShellexecuteEx failed code 255
Sounds like you may have viruses and malware. Try malwarebytes anti-malware it's FREE and it's here:
http://majorgeeks.com/downloadget.php?id=5756&file=15&evp=693ee0b20204960edfd909666f809b26
Make sure to select the non-pro version...
Install and use TDSSKiller also (Also FREE):
http://majorgeeks.com/downloadget.php?id=6895&file=1&evp=6ee854ea7c22f46734f10d4e193d17ce
You can try Superantispyware as well (Also FREE):
http://majorgeeks.com/downloadget.php?id=5116&file=15&evp=4b877f10ddee47cecae8038a2f67054e
If you don't have a good anti-virus program already you can use Avira. It's FREE as well, just make sure to configure it to "Select All" Threat categories. Here it is:
http://majorgeeks.com/downloadget.php?id=955&file=15&evp=b7cc93b8a46387032dd7756deb50bbbd
Posted on Jun 25, 2012
How do I correct the problem code C 0000001 on Windows 8 operating system
Solve Error Code 0xc0000001 in Winodws 8 Team Windows 8
Windows 8 Blue Screen of Death (BSOD) or Error Code: 0xc0000001 sometime occurs without any specific issue. You can't be sure what actually caused it. Be it a system issue or some driver problem, you may end up seeing this screen when you restart your computer.
To solve this blue screen error in windows 8, turn off your computer and when you power it up again, immediately press SHIFT + F8 key you will be resented with following screen:
Click on "See advanced repair options" and from the next screen, choose "Troubleshoot":
On the next screen, choose "Advanced Options"
In Advanced Options, choose "Windows Startup Settings"
There you will find a button "Restart". Click on this button and allow the wizard to complete all the steps. Note that it will repair your computer without making any changes to it. Once the process is completed, your computer will automatically restart and you should be able to boot windows now.
Still facing same error?
If you have followed all the above mentioned steps but got no luck in booting up your windows then probably your cause of the error is more solid and cannot be restored with mere settings reset. But don't worry, it can still be solved using windows recovery options. For this you should have a recovery/installation disc or USB Flash Drive.
Windows 8 Recovery Guide Recover When Windows 8 Fails to Boot Team Windows...
Jul 07, 2015 | Computers & Internet
How to increase volume
In Windows 8, lower right hand corner of the screen, you will see a small speaker icon (the system tray). Click on it and a volume adjuster pops up. You can figure it out from there.
Jul 25, 2014 | HP ENVY 23-1060 23" AIO Desktop PC, Intel...
Breezaaire error code
WKC 1060 ARE NON DIGITAL AND CAN NOT DISPLAY CODES,YOUR UNIT PROBABLY IS A WKCE 1060 DIGITAL UNIT IF SO PLEASE CLARIFY WHAT IS THE ERROR CODE ON IT?
Sep 15, 2012 | Breezaire WKC1060 Wine Cellar Cooling Unit
When i try to install games a have this error: ShellexecuteEx failed code 255....help please...
Jun 03, 2011 | Computers & Internet
Feb 22, 2011 | Computers & Internet
Installing Nero 8
Just down load windows installer 3.1
WindowsInstaller-KB893803-v2-x86.exe and install it on your PC. After installing the above you try installing nero 8.
This will solve the error "Cannot update MSI engine, please update manually".
Oct 15, 2007 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
