Question about Bernina Sewing Machines
The extension table on my 770QE Bernina got put in crooked and I I can’t get it out. What to do?
Posted by Joyce Hermans on
5 Related Answers
Anonymous
  • 52 Answers
SOURCE: Top cover on my Bernina 830 is crooked
there are two screws on the top one by the bobbin winder and the other by the take up lever, you should be able to adjust it from there
Posted on Jul 07, 2009
Anonymous
SOURCE: Bernina 730
I have lost the cord lead to my Bernina 730 sewing machine and cannot get any spares locally. Can anyone out there help find a replacement.
Posted on Feb 04, 2010
paj42
  • 1116 Answers
SOURCE: I have a Bernina 440 with a broken extension
You can order from a Bernina dealer or here - http://www.allbrands.com/products/abp03522.html
Posted on Mar 02, 2010
ken dourof
  • 980 Answers
SOURCE: I am looking for an extension table to fit my
The best place is to find out who services the schools sewing machines and you will find you will get that part fromn that dealer because they are always breaking Berninas.
Posted on May 29, 2010
Testimonial: "Good suggestion"
99rannellis
R.A. Ellis
  • 12731 Answers
SOURCE: Where to buy extension table for bernina 1006
It is an older model, so most likely you will find only used parts. eBay is a place to look, although I can't say I've seen many replacement parts for the 1006. Of course, perhaps the extension table fits more than one machine (although that's not very common with Bernina). You can also check out the acrylic tables (ie Sew Steady) available from several vendors online or even in some stores (you'll probably need to order what you need since they are made to your machine's specifications).
Sew Steady SST Portable Extension Table 11 5 to 32 Wide 15 to 24 Deep 1 4...
Posted on Apr 03, 2016
My bobbin is stuck in the holder and wont come out
hi Linda,
this is all i could find out.
go to this link and you will see a youtube video might help you out.
How to Troubleshoot Bobbin Problems Sewing Machine
you could also try this link.
Bernina Sewing Machines bobbin is stuck in the holder and wont come out...
Dec 10, 2017 | Bernina Sewing Machines
Bernina 770qe machine screen inactive. How do I recalibrate?
Alternative access to screen calibration:
- Access is achieved by simultaneously pressing the needle position buttons < > and switching the machine on.
- Select the cross symbols on the touchscreen for calibration.
Oct 27, 2017 | Bernina Sewing Machines
I have a Bernina 770QE. The bobbin (black) is stuck in the bobbin casing (chrome). How do I get it to release?
Take the bobbin assembly loose and turn your hand crank and move it until the hook is at the top. Pull assembly apart and clean the assembly with qtip and sewing machine oil. It will likely be dirty that is causing parts to stick. If the bobbin spring feels weak it may be a good idea to replace it.
Aug 06, 2017 | Bernina Sewing Machines
Apr 03, 2016 | Bernina Sewing Machines
Bernina 930 extention table
You can check eBay. Sometimes extension tables are available from machines that are being sold as parts. Be sure that the table will fit your particular machine. There were at least two tables made for the 930 Record, and the tables are not interchangeable.
Mar 04, 2013 | Sewing Machines
Bernina 910 sewing machine extension table
Hi Phoebe,
What you have is the extension table for the 830 and the 830E Bernina models. What you need is part number 301 276 100. This table looks a little different as it has a small see-through window in the bobbin area and also, it has no clamp (it has push-in pins). Ebay or a site like SewItsForSale is your best bet. I doubt the dealer could get one but if they could, it'd be likely around $100.
Jan 17, 2009 | Sewing Machines
Bernina 730
Jan 14, 2008 | Sewing Machines
Sewing Machines Logo
113 people viewed this question
Top Bernina Sewing Machines Experts
Chris Wetmore
Colin Stickland
Colin Stickland
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
