U-Line Icemaker Logo
Posted on Sep 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Uline Ice Machine leaking underneath?
We have a uline "built-in" ice machine with fully intergrated cabinet panel on the front. Have been noticing some water on floor. Plumber came today and when they pulled it out from the cabinets we discovered it has obviously been leaking for a very long time everything underneath was wet and mold everywhere and it has damaged our custom cabinet it sits next to. The water line in the back does not appear to be leaking. When it "cycles" and you can hear water running as if it's filling the tray it looks like water starts running out underneath. I have been noticing for a while that I thought the machine "sounds funny" when cycling on and off. I am just sick about the damage and we have turned it off and it sits in the middle of the floor while we try to figure out what to do. It was installed around 2 years ago, so we assume no warranty to cover it unless there is a recall of some sort. Please help!
Anonymous
Level 2:
  • Expert 286 Answers
  • Posted on Sep 16, 2009
Anonymous
Expert
Level 2:
Answers
286
Questions
0
Helped
114185
Points
558
Hi
I would recommend to call U-line and let them know about the problem. They would recommend to get the unit back to them so they can review it. Make sure nothing was done to the unit. Leave it as is. If they find a defect with the unit then they will ask for estimates. U-line will probably pay for the unit to be brought back to them.
U-line #1-800-779-2547
Thanks
Why isn't my U-Line 3018CLR making ice?
Isn't it obvious the compressor isn't running to freeze the water? Make sure the thermostat is working.
Brand new uline ice maker not making ice
If you have water and power to unit and no kinks in water line and water filter is not clogged then you need to call company you bought it from the machine is under warranty and repairs will be no cost to you.
ULine CLR2160S00 was making ice then the icemaking started to slow then none at all had refrigerant replaced last year and everything else seems to be working fine,,, just no ice
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
Wiring digram for under counter uline ice maker
It is on the back of the machine, if you have clear ice maker, it may be on the back of the front plate.
2answers
Uline icemaker on boat needs service..
first do a good cleaning as the manual describe.
check water supply and if still the problem, check power to cutter grid
should be 9 volts all the time
Wiring came unplugged need wiring scematic for uline ice maker
wiring diagram is on the back of the machine. If you have clear ice maker it may be on the back of the front plate.
Uline icemaker must be manually prompted to rotate and drop cubes
If your looking for a icemaker it should be part 402. Call U-line with the serial or model number to be sure they made it.800-779-2547
Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
Top U-Line Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
