Question about Freezers
My insignia ns-cz35wh9 3.5 cu. ft. Chest freezer turns on but i hear a click sound 10 seconds when you plug it in but turns off after 10 seconds and it doesnt get cold at all. What can i do or what part can i replace to fix it?
Posted by Alex Alvarez on
5 Related Answers
dididsaythat
Mike Johnson
  • 291 Answers
SOURCE: chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
Posted on Sep 20, 2007
Anonymous
SOURCE: new chest freezer not getting cold
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
Posted on Aug 24, 2008
Anonymous
  • 68 Answers
SOURCE: my kenmore freezer does not turn on at all
u either need a new thermostat or your compressor is dead
Posted on May 02, 2009
  • 6239 Answers
SOURCE: After being unplugged for one year, my Frigidaire
It's probable that you've lost refrigerant in the cooling system. Unfortunately, leaks in those systems can be hard to find so check your warranty to see if the labor is still covered.
Posted on Oct 26, 2009
Raz Mataz
  • 389 Answers
SOURCE: We have a 21 cu ft 2009 chest freezer. It is not
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
Freezer starts then stops
Either the start relay on the compressor is bad OR the compressor is bad.
Replace the start relay and find out which it is.
When you remove the relay you may see a burned spot on one or more of the relay terminals.
If so,it is definitely bad.
Apr 26, 2010 | GE 24.9 cu. ft. General Electric Chest...
Won't turn on
To determine which component has failed please do the following.
Unplug the freezer wait 5 minutes and plug back in. Listen closely for any sounds by the compressor. If you hear a click or hum followed by a click the problem is the compressor and would cost about $400.00 to repair.
If you do not hear any sounds the problem is most likely the cold control or sometimes called the thermostat. The part number is WR09X10053 and is about $25.00
Apr 25, 2010 | GE 5 cu. ft. / 142 liter Chest Freezer...
Plug it in, a click is heard but no compressor coming on, doesn't freeze
The click sound that you hear is from the clixon (overload protection) on the compressor.This means that the compressor is tripping on overload.
Regards
Andre Nagel
Mar 22, 2010 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Kenmore chest freezer wont cool
Hi.
Here is a tip that will help you...
There are also more tips at the bottom of this one...
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
heatman101
Feb 26, 2010 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Picked up used chest freezer...plugged in and briefly clicks...I can hear it energized for about 5 seconds then quits....it then repeats this cycle. It was on its side when delivered
Try to replace the compressor relay (most of the times problem) ,but if still doing the same clicking noise , the problem is in the compressor.
Sep 29, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
New chest freezer not getting cold
Jul 13, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Freezer not working
compressor is faulty. clicking noise you hear is the overload for the compressor. not worth repair and not diy
Mar 18, 2007 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezers Logo
219 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
