Question about Samsung Office Equipment & Supplies
Check the sensors on the paper path ( from the tray to the exit ).
Posted on Sep 29, 2019
SOURCE: canon iP 3300 printer service error 6502
CANON PIXMA IX IP 4000 - error 5100 and error 6502
While testing the printer the cover must be closed!
So if you have a CISS in your printer you have to close the cover after replacinq cartridge because after that
replacinq the printer is testinq the cartridges also with the blinkinq LEDS which are installed on the ink's!
There is a light LED sensor under the cover which detects the blinking.
So if you have destroyed the LED on chips or if you covered them with glue OR if you will leave the cover opened
and press cover-open detection button with a pen (then the day ambient light will come inside to cover)
you will get an error 6502 or error 5100. I think that the same error will come with all printers which use
CLI8 CLI-8 cartridges.
Remebre that the blinking led have to be clean and blink after installing new cartidge.
Other reason is that you mixed the chips ang give i.e. chip from yellow to blue and blue to i.e.red. and black to yello etc etc. (YOU MIXED THEM :) )
I hope it will help
Posted on Jun 16, 2008
SOURCE: Paper Jam
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine:
Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine)
Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part).
Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.
Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
SOURCE: Clear Paper Jam error -- but there is no paper jam!
I have the same problem. Answer? PUt the piece of junk in the trash and never, never buy brother products again. I called Brother and they had a refurb for more than what it cost me originally!!!!!
SOURCE: Paper Jam error
try to open the cover and reseat the ink.
the machine is trying tell you there is something stuck inside where the switch or the senser is located. usually right before the heater path. after the paper pickup roller.
Posted on Oct 15, 2008
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
Apr 05, 2013 | Samsung CLX 3160fn All-In-One Printer
Feb 21, 2013 | Samsung CLP 315 Laser Printer
Apr 01, 2011 | Samsung SF-565PR/XST Printer
Oct 06, 2010 | Samsung SCX4623F Laser All-in-One Printer
Feb 12, 2010 | Lexmark X340n All-In-One Laser Printer
Jan 04, 2010 | Samsung ML-3051N Laser Printer
Dec 29, 2009 | Samsung SF-531P All-In-One Laser Printer
Jul 01, 2009 | Samsung SCX-4100 All-In-One Laser Printer
May 05, 2009 | Samsung CLX 3160fn All-In-One Printer
May 18, 2008 | Samsung CLX 3160fn All-In-One Printer
37 people viewed this question
