Question about Cooktops
Just a simple reconnect question. need to reinstall the old jenn air 8130 cooktop. 220 from wall is white and black and copper. cook top is Black, red, white and green. what goes back where
Posted by BTX btx on
5 Related Answers
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Posted on Nov 16, 2007
Anonymous
  • 186 Answers
SOURCE: COOK TOP WIRING
 You have Red and Black HOT wires and a Green Neutral - That is 220 volts. From the wall - Black is Normally HOT and White is Neutral. That is 110 volts. If that is a typical household outlet, is will only supply a demand at about 15 amps while running at 110 volts. Your Cooktop will most likely demand somewhere around 50 amps at 220 volts. - Short Answer - You will need to have a 220 volt supply line ran to the cooktop from the breaker. Easy to do but dangerous if you are unfamiliar with high voltage.
Posted on Apr 30, 2008
SOURCE: wiring problem
yes that is right, color to color turn of breaker before touching wires. green and bare copper go together.
Posted on Nov 04, 2008
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Posted on Nov 15, 2008
Anonymous
  • 491 Answers
SOURCE: I am installing a Jenn Air JED8430 electric
IF THERE IS NO COLOR FLEX ON THE COPPER WIRE THEN CONNECT THE BLACK WIRE TO THE RED .
Posted on Nov 08, 2009
3 wire cook top to a 4 wire outlet
Older 3 wire connectors where Wht=Neutral Ground Return, Red=One Phase Hot, Blk=Second Phase Hot, of 220VAC stove connections.
Newer Electrical code standard has a forth wire that is bare copper for a separate safety ground return.
I suggest you but a 4 wire pig tail cable for your stove top, available at Depot or Lowes, and connect 3 wires of this 4 wire cable just like the 3 wires are now connected. The 4th bare copper safety is attached to any metal part of the stove. Find a screw you can loosen to wrap it around and tighten.
Mar 02, 2009 | Jenn-Air JED8230 Electric Cooktop
Fixing wiring
yes, that is the correct wiring
Feb 08, 2009 | Jenn-Air JED8430 Electric Cooktop
Wiring problem
Nov 09, 2008 | Jenn-Air JED8430 Electric Cooktop
Wiring problem
Nov 01, 2008 | Jenn-Air JED8430 Electric Cooktop
COOK TOP WIRING
Apr 30, 2008 | Jenn-Air JED8430 Electric Cooktop
Wiring...please help ASAP in the midlle of project now
white to white green to copper red and black to black
Apr 12, 2008 | Jenn-Air JED8430 Electric Cooktop
JEC8430 ADB cooktop wiring doesn't matchup - no instructions for this situation
hook the copper and white together. DO NOT leave the white unhooked.
Nov 24, 2007 | Jenn-Air JED8430 Electric Cooktop
On Cooktop From Box
Black to Black
White to Ground
Nov 16, 2007 | Jenn-Air JED8430 Electric Cooktop
Cooktops Logo
129 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
