Question about Refrigerators
Do you need to replace both main board and interface board for SY CE error on Frigidare galley model LGHB2867PF7
Posted by lisa bierce on
5 Related Answers
John
SOURCE: Same prblem as person who listed Alarm going off
I ended up buying the parts from Electrolux - cost $384 plus tax. The repair is relatively easy and you can do it yourself. My problem was locating the main power board - who would have thought it would be behind the front kick plate attached to the bottom of the refrigerator.
Posted on Oct 21, 2011
Anonymous
  • 347 Answers
SOURCE: whilpool duet model # gew
Only after checking the door switch and the belt switch,these are two other items that can cause your problem...
Posted on Sep 16, 2010
GodBlessU
Aparajita Batabyal
  • 3513 Answers
SOURCE: Frigidaire Gallery side by side
Hi
If you have unplugged the unit for at least 5 minutes and the error code keeps coming back then this will be a warranty concern. Any attempt by you to correct the problem aside from resetting the unit (unplugging it for 5 minutes resets the main control board) will void your warranty.you have to call the dealer or frigidiare service center.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Aug 17, 2011
cshotwell
cshotwell
SOURCE: What does "SY CE" on the LED control mean
I just got the same note on mmt refrig. Do u know the answer?
Posted on Oct 25, 2012
KimSland
  • 58 Answers
SOURCE: firmware on main board 10000100 error
Live (free support) chat with Epson:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&category=Products&infoType=Contact&oid=14397&prodoid=19302859
Posted on Nov 06, 2013
My refrigerator has these codes SY and CE. It's a 2009 Frigidaire Gallory, side by side. It stopped cooling and the compressor tries to fire up but only 2-3 seconds.
Typically error code SY CE, is commonly referred with an issue between the main control board and the user interface (the control on the Freezer door). A tech would typically check the communication wiring wires between both parts to determine the cause of the error code. If the wiring is correct, then more than likely you are looking at a faulty main control board or user interface. Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. Appliance 911 Appliance 911 Sea Breeze
Aug 10, 2015 | Frigidaire Refrigerators
I have a frigidaire refrigerator with electronic screen about a wk ago started beeping giving me a code of sy ce what does this mean?
Thank you for your inquiry, Carlos!
From the information you have provided your Frigidaire refrigerator is displaying an error code of "SY CE" and you would like to know the meaning. The error code "SY CE" stands for communication error at power up. This could be an issue with your wiring harness, main control board, or user interface board. I would recommend performing a reset on your refrigerator and you can do that by unplugging the power cord for at least ten minutes. If that does not correct your issue I would suggest seeking assistance from a professional technician for proper diagnosis and repair. This will help you to avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
May 26, 2015 | Frigidaire Refrigerators
WHEN IT DISPLAYS 5Y CE WHAT DOES THAT MEAN?
The SY CE error indicates that the user interface (key #2) and the main control board (key #38) are not communicating properly. You can check the wiring. Unplug the refrigerator and gently pry the the dispenser away from the refrigerator. (Use a putty knife and work around the edge of the dispenser.) Check that the connections are clean and tight. Check the connection under the hinge cover, as well.
If the wiring doesn't have any damage, one of the above boards needs to be replaced. Additional testing will be needed. If you add a comment with the model of your Frigidaire, I may be able to provide information about the parts.
I hope this helps.
Mar 12, 2015 | Frigidaire Refrigerators
Throwing code --sy ce
Thank you for your post, Friend.
Typically error code SY CE, indicates an issue between the main control board and the user interface (the control on the Freezer door). A tech would typically check the communication wiring wires between both parts to determine the cause of the error code. If the wiring is correct, then more than likely you are looking at a faulty main control board or user interface. Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect. - Z
Aug 11, 2014 | Frigidaire Refrigerators
What does Error code SY and CE mean?
Thank you for your question, Friend.
Typically error code SY CE, is commonly referred to an issue between the main control board and the user interface (the control on the Freezer door). A tech would typically check the communication wiring wires between both parts to determine the cause of the error code. If the wiring is correct, then more than likely you are looking at a faulty main control board or user interface. Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect. - Z
Aug 07, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
Why is refrigerator beeping and the digital panel shows "sy" and "ce"?
Good Afternoon Friend, this is Z! I am happy to assist you!
Typically error code SY CE, is a common error between the main control board and the user interface (the control on the Freezer door). A tech would typically check the communication wiring wires between both parts to determine the cause of the error code. If the wiring is correct, then more than likely you are looking at a faulty main control board or user interface. This is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
May 21, 2014 | Frigidaire Refrigerators
Model fghs2655ke0- clicks at switchboard. everything works just powers on and off. eventualy a sy ce error code. got the new replacement switchboard (main board) and install with new harnesses. will not...
Hello Steve, thank you for your inquiry! SY CE is commonly referred to an error code between the main control board and the user interface (the control on the Freezer door). A tech would typically check the communication wiring wires between both parts to determine the cause of the error code. If the wiring is correct, then more than likely you are looking at a faulty main control board or user interface since the MCB has already been replaced. I would please recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Aug 01, 2013 | Frigidaire Refrigerators
Error message 5y ce
Good Afternoon Cheryl, I am happy to assist you. Could the error code possibly be SY CE? If so, error code SY CE, commonly refers to a communication error at power up. Let's try resetting the refrigerator by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn on the refrigerator. If resetting the power does not correct the issue, than the unit could possibly be experiencing a communication problem with the control board or a faulty user interface board. In this regard, I would recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered.
Jul 30, 2013 | Electrolux EI23BC56IS (226 cu ft) Bottom...
Sy ce on fridge door
Hello Debbie Lee - Typically error code SY CE indicates that the refrigerator has detected a communication error at power up. Contact a professional to move forward accurately to check the wiring between main control board and user interface. Depending on the diagnoses, either or will need placing.
Feb 02, 2013 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Lcd reqds 5y ce
Hi John Dirksen- Could the error code possibly be SY CE? If so, it typically means that the unit has detected a communication error at power up. A professional will need to check the wiring between the main control board and user interface. Depending on the diagnoses from the professional either part may need replacing.
Jan 13, 2013 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
