Question about Bose Audio Players & Recorders
How can i see my bose woofer is on any sign she is oN?
Posted by nilo olares on
My bose system does not respond to the remote. It is a patio system. Inside works fine but I cannot turn the outside off or correct the volume. I just got a new remote- same problem
Maybe, just Maybe you could try turning the power off for the sub woofer, the zone next and then the Bose itself. Power up the woofer and zone before the Bose and it may pick it up, works when the Apple TV drops out
Jul 10, 2014 | Bose Lifestyle 48 System
Bose woofer acoustimass 20
Have a acoustimas 20 woofer. Since it is the only thing I have I tried to custom connect it to a source (my mp3 player) to get a signal. It all worked fine by soldering the wire terminals straight to the pins of the DIN. All worked fine until I turned up the volume on walman and maxed out the 2 settings on the woofer, The woofer died after that. I am trying to find what could have gone wrong, any help would be greatly appreciated.
Aug 06, 2012 | Bose Acoustimass 20 System
I have a Bose powered sub woofer, which I would like to connect to a pioneer receiver, the subwoofer (model 2683) connection has a four pronged connection (yellow white red blank) and the receiver has a...
Hi,sorry but you can not connect it directly like other sub-woofers..
Bose 2683 Powered Subwoofer is part of Bose Lifestyle 5 system, Please note that you will need the 5-pin DIN cable that connects the subwoofer to the base or "Music Center". and the 4 pronged connections for its own stereo speaker output not input from another stereo..
Sorry....but if you can arrange some handy man nearby ,he may get into the DIN cable to locate the subwoofer signal 2x input leads than you can use that leads for connecting into single sub woofer out let of your system...otherwise try to sell BOSE which can easily buy brand new up to date powered sub..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 21, 2011 | Audio Players & Recorders
My bose pod is not working
hi, First, unplug the power directly at the back of the woofer while the unit was on;
Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
It worked like a charm. I hope this is helpful!
goodluck
Jan 20, 2011 | Bose Companion 3 Computer Speakers
Bose Lifestyle 5 speakers(woofer + 5 double cubes)
I repaired the contol unit per instructions from a post at FixYa.
Sep 11, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Connecting Bose Acoustimas Wofer to a Sony receiver
you cannot hook a bose system up with any other system not even another bose
Jul 01, 2008 | Bose Cinemate Digital Home Theater System...
Bose acousticmass 15 sub-woofer making a noise
The sub contains the amp for the other speakers. But it sounds like the amp has a seriously damaged section and will probably have to be serviced by Bose.
Jun 24, 2008 | Bose Acoustimass 15 System
Am setting up a bose GSX 3-2-1 home theater
Need to know the TV connections. On newer TV's there RCA jack connection or ext speaker connections. Usually the external TV speaker connections hook to the woofer and the rest of the speakers are connected to the woofer. The woofer acts as the sound system for the rest of the speakers. With this method you need to mute the internal TV speakers by a swiich on the TV or internal TV setup menus and select ext speakers.
Jan 26, 2008 | Bose Cinemate Digital Home Theater System...
46 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
