Question about Toshiba Televison & Video
Toshiba SD-V296KU won't rewind most of the time
Posted by brit hurlington on
2 Related Answers
micromatikal
Tim Grayson
  • 2777 Answers
SOURCE: What type of cd-rs will a Toshiba sd-v296ku play?
For whatever reason I can't find that exact model number listed anywhere (as far as a spec sheet or manual) but the only type of cds it could possibly play would be either:
Music CDs
VCDs (video cds)
or SVCDS (super video cd)
Only select dvd players will play the latter two, so make sure it is listed as being able to do that (most players will have logos / icons on the front of the player depicting what it will play).
Posted on Jun 30, 2009
Anonymous
  • 16 Answers
SOURCE: how can I register my
You will have to fill the following form: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=ProdReg.
Posted on Apr 08, 2011
Tip
This doesn't seem to be working for me. The BACK button (single arrow pointing...
I selected the progressive botton on the menu and locked the whole System, please gime some tips so that i can solve this problem
on Jul 07, 2008 | Sony RDR-VX515 DVD Recorder/VCR
Toshiba dvr670ku - vhs tape won't play, shuts recorder off
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
Oct 14, 2012 | Toshiba M754 VCR
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Are the SD-V296 and the SD-V296KU the same. My instructions on the KU does not say you can copy from VHS to DVD. Reviews I have read says the SD-V296 does copy from VHS to DVD.
Neither of these units can record to DVD; they are DVD players. I believe they are the same unit (the extra letters indicate a region code for the player).
The manual for the SD-V296KU is available from Toshiba here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2805081&rpn=undefined&modelFilter=SD-V296KU&selCategory=2797338&selFamily=2797344 .
I hope this helps.
Jul 22, 2011 | Toshiba SD-V296 DVD Player/VCR
Trying to do a timer recording to a Toshiba SD-V296KU DVD Video Player/Video Cassette Recorder. all seems to go with the recorder device but when I do the playback it is a blank screen. Is that because the...
I have a Toshiba DVD Video Player/video Cassette recorder - the problem is that when I set the VCR to record for an hour it will record for less than that hour and eject the tape. Help!
Mar 01, 2011 | Sansui HDLCD-4212 LCD TV
I''m having tracking problems with my toshiba dvd/vcr combo SD-V296KU ive used a head cleaner but it still acts up i got it to work clearly for about an hour but then it went back worse then it was to...
Using cleaning tapes will wear the heads if not used with care and no more that a few seconds at a time.
The line in the centre of the screen is the tape being creased and that may be caused by a worn pinch wheel.
If the RF from the heads is low, the auto tracking will not work and a new drum assembly will be required.
Consult a Toshiba service centre.
Jan 16, 2011 | Televison & Video
Was rewinding a tape, then the unit shut off. Now will not turn back on. No power at all.
www.tacp.toshiba.com/tacpassets.../SD-v394/.../SD-V394_om_e.pdf
http://www.tacp.toshiba.com/tacpassets-images/models/SD-v394/docs/SD-V394_om_e.pdf
http://manuals.electromaniacs.com/category.php?id=176
OK above is some links for your user and a service manual.. use these to troubleshoot and hopefully repair your unit. This sounds like a thing called a Mode switch, inside the VCR going faulty. If you cannot sort it yourself, you need to take it to a Toshiba authorised service center and ask for a "Quote"
May 17, 2010 | Toshiba SD-V394 DVD Player/VCR
What type of cd-rs will a Toshiba sd-v296ku play? Do they have to be recorded in a specific format?
Music CDs
VCDs (video cds)
Jun 30, 2009 | Televison & Video
Open Questions:
Televison & Video Logo
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
