Question about Hardware & Accessories
SOURCE: I have digital programmable timers
DT121 Manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt121c%20-%20english.ashx
All Intermatic manuals
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Intermatic does not show DT11
Intermatic shows the DT121 is no longer available
If the display shows and you can set programs, then the battery is good.
Does the manual override work? This indicates whether the timer on-off switch operates.
If manual override does not work, then I discovered that timers are no longer any good
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Posted on Oct 12, 2010
Oct 10, 2014 | Intermatic & Digital Plug in Timer
The timer has 3 settings ON, OFF, and TIMER. To control the load manually, place the slide switch in the
"ON" or "OFF" position. To use the timer,
1. Place the slide switch in the "TIMER" position
2. Rotate the dial Clockwise until the desired time lines up with the arrow in the center dial.
Jan 25, 2011 | Woods Inwall 24 Hour Programmable Timer
Dec 17, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Dec 13, 2010 | Hardware & Accessories
Nov 25, 2010 | Hardware & Accessories
Oct 31, 2010 | Intermatic Hardware & Accessories
Oct 12, 2010 | Intermatic Hardware & Accessories
Aug 04, 2010 | Dryers
Jul 30, 2010 | GE Hardware & Accessories
Sep 04, 2009 | Dryers
Feb 12, 2020 | Hardware & Accessories
142 people viewed this question
