Question about Panasonic Viera Tc-p50c2 50-inch Class Television 720p Plasma Hdtv
Panasonic Tc-p50c2 has no picture, has audio with a buzzing sound and the power led is a steady red.Can't get in to the self check mode with no picture.
Posted by billymon63 on
5 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
http://servicemanuals.vstore.ca/
Posted on Oct 14, 2008
Anonymous
SOURCE: Panasonic Viera TH-50PZ80U No sound no audio only buzz.
Found the screen had a small crack and was shorting the video circuit.
Posted on Jan 09, 2009
Anonymous
SOURCE: Model TC-32LX700 Power indicator light on from is
Problem is caused by voltage irregularity. Pulled plug for an hour and then plugged it back in. TV reset and it works fine. If this does not work it needs a TV technician.
Posted on Sep 15, 2009
caroldon
  • 17130 Answers
SOURCE: Panasonic PT-60LCX64 does not power up
There could be a possible failure of the Ht circuit, check on your Ht Drive output trans, the LOT, any shorting in the HT capaciitors, short in the LT line. You will need to probe into the power side as there is a safety switch off. the microcontroller is working fine and hence trace carefully looking for damaged resistors, capacitors or transistors in the power side.
Posted on Jun 29, 2010
bulbguy
John Reilly
  • 37 Answers
SOURCE: Red power light and buzzing sound with red lamp light.
If the lamp does not light at all, it is probably a bad lamp. The buzzing may be the ballast trying to start the lamp or a problem with the power supply. Check the lamp and see if the arc tube is broken. If its a new lamp, you should be under warranty. I have the manual if you want to go to me site at allprojectorlamps.com. Just send you email to me attention Bulb Guy
Posted on Aug 17, 2010
Panasonic TC-L47DT50 no picture no sound front lights com on
No picture or sound in my Panasonic TH-P42UT30A plasma ...
https://www.ifixit.com/.../No+picture+or+sound+in+my+Panasonic+...
iFixitAug 1, 2014 - Hi Ifixit,. I've got a Panasonic th-p42ut30a plasma tv that has a fault with it. The standby light is on (red) but it doesn't come out of standby.Missing: l47dt50
Panasonic Product Support - TC-L47DT50
shop.panasonic.com > Get Support
PanasonicSMART VIERA® 47" Class DT50 Series Full HD 3D LED HDTV (46.9" Diag.) ... Issues Addressed: Solves issue where the Emergency Alert System is displayed on the TVhours after the termination of the message. Solves issue where the Emergency Alert System is displayed on the TV hours after ...
Panasonic TX-P42X50B No Picture Or Sound ' Dead ...
? 9:00
https://www.youtube.com/watch?v=EanHoWLLpxU
Nov 6, 2014 - Uploaded by Electronic Workshop
Panasonic TX-P42X50B No Picture Or Sound This plasma television ... TV repair, clicking and will not power on, loud snap,no picture, etc.
1helpful
How do I get rid of the red x in the middle of the screen?
I think you are in service mode.......try unplugging the power from the mains for 15 minutes then power back up.
1helpful
My 50" Panisonic TV lost the picture and it black, when i turn it on the red power light comes on then starts blinking.
How many blinks you get, Panasonic has a diagnostic blink code to help with troubleshooting, it might indicate an issue with the internal supply, SC cards or main A module.
2helpful
2answers
1helpful
Where to plug in head set to panasonic tv tc p50c2
You can see the following Pin terminals on the Panasonic TC P50C2
Insert the connecting cord (phono plugs shown below) provided with your Sony MDR-RF960RK to the above terminal such that the colors of both plugs and terminals are matched.Insert it firmly.
Thanks for choosing Fixya.
Panasonic Viera Tc-p50c2 50-inch Class Television 720p Plasma Hdtv Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
