Question about The Kitchen Appliances - Others
I was given a pressure from an older aunt, the cooker looks to be very old.Cant find a model no. Just an item no...007.0102.07. Can you give me any idea as to how old this pressure cooker is? Thanks
I want to jnow the approx age of this pressure cooker
Terry
  • The Master
  • 11,377 Answers
If you search using https://www.google.com/images the words pressure cooker, you might see a similar model. Then you could provide the manufacturer and possibly the model so it might be possible to identify it.
Posted on Sep 27, 2019
5 Related Answers
bestdarngood
Benjamin Patri
  • 3037 Answers
SOURCE: Cooks esentials pressure cooker
osborne, that link is no help whatsoever.
Theres a yahoo group that has this pressure cooker manual and lots more manuals: http://groups.yahoo.com/group/PressureCookerRecipes/
I don't believe you will find one without someone sending it to you, by joining this group, someone should be able to fax you or email one to you, good luck and let me know if you need further help
Posted on Apr 03, 2008
Anonymous
SOURCE: I can't open my new Ultrex 2 Pressure cooker model 11302
It's almost certainly due to atmospheric pressure. Warm it slightly and it will open.
I had the same problem with an underwater dive torch. Left Johannesburg (1000 metres above sea level) and went to Mauritius (10 metres above sea level) and I couldn't open torch!
Posted on Apr 20, 2008
Anonymous
  • 319 Answers
SOURCE: lost owners manual
I have found one on EBAY for a 6 quart that the seller lists as exactly the same as the 8 quart model.
Here is the link.
Let me know if this helps!
Brian
Posted on May 18, 2008
Anonymous
  • 34 Answers
SOURCE: I need a english manual for a Toshiba RCK B5X rice cooker
you should have a lever you push down to cook and it comes up when the rice is done,,
Posted on Feb 17, 2009
Anonymous
  • 496 Answers
SOURCE: Manual for CEPC800 Cook's Essentails Pressure Cooker?
I hope this link is what you're searching for:
http://www.qvc.com/man/k/k37000_man.pdf
Posted on Sep 21, 2009
I need to find a cool touch handle for the cooks essential pressure cooker model 99700
Cooks Essentials 99700 5 qt Electric Pressure Cooker ' eBay
www.ebay.com/.../Cooks-Essentials-99700...Pressure-Cooker-/2211...
eBayItems found similar to "Cooks Essentials 99700 5 qt Electric Pressure Cooker". Items in search results. Item image · Cook's Essentials 5qt Electric Pressure CookerPressure Regulator Knob & .... Aluminum Pressure Cooker XLT Model YPC-1045 ...Cooks Essentials liner/pot for Pressure Cooker #99790 Replacement part ...
How to Replace Parts on a Cook's Essentials Pressure Cooker
www.ehow.com > Home
Your Cook's Essentials pressure cooker is manufactured to work without ... for myCook's Essential pressure cooker model 99700...any suggestions where I can ...
Dec 28, 2015 | Coffee Makers & Espresso Machines
I need a rubber seal for my pressure cooker model 99700 ELECTRIC PRESSURE COOKER
4 quart cooks essentials pressure cooker - YouTube
? 7:04
www.youtube.com/watch?v=JIGVz1HcDlc
Jan 6, 2012 - Uploaded by wtbm123 My magic pot. ... Electric pressure cooker that has a timer so u set it and... ... without some kind of water ,it would not make enough pressure to seal the pot . .... I cant find one online anywhere, is there another model that fits?
Cook's Essentials PRESSURE COOKER - Fixya
www.fixya.com/support/t318063-cooks_essentials_pressure_cooker
Cook's Essentials PRESSURE COOKER WOULD YOU KNOW WHERE TO GET A NEW GASKET FOR CEPC600S PRESSURE COOKER? ... part,, pressure regulator knob cooks essentials electric pressure cooker model # 99700 5 qt. ..... Looking for a replacement gasket for my 10 qt Innova model 42010 pressure cooker.
Oct 27, 2015 | Kitchen Appliances - Others
I need the instructions for above item
Unfortunately, fixya does not show the model and brand name of your pressure cooker. A safe bet is that you'll find an electronic copy of your pressure cooker manual here:
http://www.hippressurecooking.com/pressure-cooker-manual-library/
May 28, 2015 | Kitchen Appliances - Others
I'm not sure what is the model number of my pressure cooker, but this handle looks like...what is the ring seal for this model? What if i order it and it doesn't fit?
Ana, on the handle of the pressure cooker or under the bottom of the pot it should say both the Brand & Model number. There are a ton of different gaskets for pressure cookers, the Presto brand alone makes 20+ different gaskets just for their pressure cookers.
Most companies do not allow returns of items that are opened and installed so it is best to look under the pot and get the brand and model information. Then from there you can correctly research the gasket that will fit your Pressure Cooker.
Mar 12, 2015 | Maitres Rochedo 59329 Maitres Pressure...
I need a user's manual for QVC product CEPC900R
You didn't say the cooker's brand name. QVC sells several versions. Check these links until you find a picture of your pressure cooker!
Cook's Essentials:
http://www.hippressurecooking.com/category/manuals/cooks-essentials/
Deni:
http://www.hippressurecooking.com/category/manuals/deni/
Good Luck!
Oct 18, 2014 | Home
Pressure cooker is not heated on induction cooker
Likely the pressure cooker base is not induction-compatible. This is the case with all aluminum pressure cookers and some older stainless steel models. Your cookware store will have a small metal plate that you can put on your induction burner to heat non-induction compatible cookware.
Nov 10, 2013 | Home
Can I buy replacement parts for my Innova pressure cooker model #07708 8qt? I need part #42252- 2 piece pressure regulator.
Hi Alex...
The most trusted site is amazon (for buying parts and items), so I have found this Amazon com innova pressure cooker parts
take a look, and see which one fits.
enjoy
Jan 28, 2012 | Home
I have just purchased this appliance from the local Hospice shop. It has the top pressure balance knob thing (if this is any help) but I have no idea how to use it. There is alot of information on sites...
Just sounds like an old school pressure cooker. Look up Pressure cookers online and you should be able to find instructions. Try looking up this, is this what you have??
Presto 01362 6-Quart Stainless Steel Pressure Cooker
Aug 24, 2017 | Microwave Ovens
Looking for place to order replacement Seal Ring for float valve for my old Wolfgang Puck Pressure cooker.
Replacement parts for the Wolfgang Puck pressure cookers are available here:
http://www.wpcookware.com/categories.asp?cat=29
If you do not see the part you require or are unsure about the model number; suggest you contact their Customer Service at 1-800-275-8273 or via their webform at:
http://www.wpcookware.com/contact.asp
Sorry someone has not responded sonner.
Sep 10, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Jan 15, 2009 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
115 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
