Question about Hilti 202415 PD 4 Laser Range Meter
How to mesure in feet instead of inches
Lost my Hilti Pd4 user guide. How do I switch from measuring in inches to measuring in feet? Only has the on/off button and the "measure" button so there must be some trick.....
Posted by beater5liter on
Hilti fixer
    New Friend:
    Problem Solver:
  • 5 Answers
Hold the POWER button down for a few seconds. Thats how you get into the settings. Cycle through options with the measure button. Use the power button to go to the next option (eg, beep on or off). Press and HOLD the power button to exit this mode.
Posted on Jan 22, 2013
Anonymous
    Sergeant:
  • 384 Answers
If there only two buttons, I would try holding one down for about 3 seconds to see if there is a change in display, or hold both down for the same time period. It has to be a combination of the these switches. Good Luck!
Posted on Sep 16, 2009
DINESH PATEL
    New Friend:
I dont know how to change in my hilti matchine feet to meter..please help me...give me a solution....
Posted on Jun 26, 2013
  • DINESH PATEL Jun 26, 2013
    i dont know how to change in my hilti matchine feet to meter..please help me...give me a solution....
  • Sateesh Magal
    Sateesh Magal Apr 08, 2017
    Very Helpful. The Manual is Poorly Organized.
Why does E107 comes up on my hilti PD4 screen and how can I fix
I had same problem on PD42 but code was E112. It normally comes after 3 seconds of switching on and by carrying out following steps it works.
Switch ON and start pressing plus button repeatedly and if battery symbol comes in left corner its working. Actually its 3 seconds when you need to press plus button when it beeps and error message comes on, but its much easier to keep pressing and try your luck. This is not permanent fix but will work every time you want to use it.
Sep 16, 2014 | Camping, Backpacking & Hiking
Kenmore dryer 86984810
pi r squared * depth to calculate this mathematically. Get a tape measure and measure the distance of the center of the drum to the edge, multiply that by itself. Then multipky that by 3.14. then measure from the back of the drum to the front edge and multiply by that. For example the dryer is 24 inches deep and has a 12 inch radius. 12 times 12 is 144 times 3.14 this is 452.16 times 24 equals 10851.84 cubic inches. divide that by 1728 to get cubic feet. You can do this in feet instead so it is easier. http://www.ehow.com/how_5622710_measure-dryer.html
Jul 09, 2013 | Dryers
HOW TO CALIBRATE A HILTI PRI 2
To check calibration, take it into a hilti center. they'll check it for you. Otherwise, set it on a countertop or table. Mark its level at a distance of 15 feet, rotate it 90 degrees, and check to see if the marks jive. If the dont a calibration will cost $60 plus shipping. call 800 879 8000.
Nov 13, 2012 | Hilti Rotating Laser Pri 2 331411
Can you buy replacement screens for a Hilti pd4....and fix them myself
perhaps they never read the question i also need a new screen did you manage to find one
Jan 22, 2012 | Measuring Tools & Sensors
How big inside (cubic ft.) is the Roper refridgerator
20.9 cubic feet for model # RT21AKXKQ
14 cubic feet for model number RT14BKXKQ05
Jun 07, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Fat max laser is in inches need feet
Press and hold the "+ - units" button and hold for over one second. It should then let you select your units of measure. In this case it should be the second selection, which is "0.00 ft". If you lost your owners manual, you can download one at www.engineersupply.com/Manual-and-Help-Docs/Stanley-TLM100-Manuals.pdf. If you find this helpful, please rank the solution.
Mar 11, 2009 | Grip On Tools Stanley& Fat Max Tape...
Hilti 202415 PD 4 Laser Range Meter Logo
1,732 people viewed this question
Top Hilti Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Hilti Measuring Tool and Sensor Expert? Answer questions, earn points and help others
