On my sd-p403 if i turn power on it will stay on for 1 to 3 seconds and then shut off again, after trying several times it continues to do same thing. Can you tell where or what the problem is?
Bad connection. if you have some electronics experience, unplug the tv and carefully open the back , remove the main bord and check for soldering using the magnifier. if you check very good , you will see a sort of small line around the soldering . that small line are bad connection , re-solder them .
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
