Acer Aspire 5100 Notebook Logo
Posted on Sep 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The orbicam is not workin i have vista. i cant find the software online
Anonymous
Level 2:
Scholar:
  • Expert 54 Answers
  • Posted on Oct 12, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
54
Questions
0
Helped
19033
Points
160
If the Acer Orbicam program itself is not responding all you need is just recreate the Pictures folder where snapshots of your webcam are being saved automatically.
That Pictures folder is located on Desktop>User (which is your user logon account)> Pictures.
Basically, just copy your photos to a new folder, delete the Pictues folder and recreate it, then paste your backed up photos.
If the camera won't stream video, you could uninstall and reinstall the Acer Orbicam from Add/Remove programs.
Click this link for direct download for Bison camera driver for Acer Aspire 5100.
Just run the Setup.exe from the root folder for automatic install.
As for the Acer Orbicam program itself, run the setup.exe under the BSU folder.
Anonymous
Level 1:
  • Contributor 42 Answers
  • Posted on Sep 15, 2009
Anonymous
Contributor
Level 1:
Answers
42
Questions
0
Helped
14680
Points
93
Here ya go....
http://support.acer-euro.com/drivers/notebook/as_5100.html
choose bison acer orbicam
Acer orbi cam
thats the link for the orbicam software provided by acer
please be sure to rate me! thanks!
http://www.acerpanam.com/synapse/data/7117/documents/AcerOrbiCam(Bison)_v1.0.0.19.zip
Acer orbi cam
Try one of these links
acer-orbicam.software.informer.com/
www.versiontracker.com/dyn/moreinfo/win/67086
Acer orbi cam
my laptop is an acer travelmate 3275wxmi and the orbicam is not working. when doubble cliking the icon, it always return to the main menu, how can i solve this problem?
thanks
2helpful
Acer orbi cam
you probably havent uninstalled it cos it's built in and on the next reboot it would have been found and the driver installed, but if you need the driver, go here and go down to vista and select Logitech Orbicam, or if you mean the camera will not come on when you click the opening software (as many 100's also have the same problem), try this its worked for most people.
Double click the cam opening software, then turn the camera (if you have a 225 Degree swivel one) to face the rear of the lid, then turn it back again, then keep clicking the software that is supposed to open it until it connects.
Acer OrbiCam not working (acer aspiral9412zwsmi)
Has it worked in the past, on this computer?
Have you recently upgraded to Vista?
Here is a suggestion:
There are two software entities involved – the camera Drivers and the OrbiCam application itself
The new driver and a new version of webcam application (below)
The correct files to download are:
Acer Orbicam driver (Bison)
Acer Orbicam Bison utility 1.0.0.13
These can be found here under the MS Windows Vista drop down menu:
http://support.acer-euro.com/drivers/notebook/as_9300.html
You need to download and install them both.
Acer orbicam and the audio stoped working
Try to get driver from acerpanam.com, i believe there are 3 type of orbicam, you have to try one by one,
Try to update the driver for audio too
Hope this will solve your problem
2answers
The orbicam will not work on my aspire 5052AWXMi - I am using Vista. If you open up the orbicam is just says no camera detected. I have looked to update the driver, removed and re-installed etc, but no...
Is the driver fits on Vista? If yes, try this one, remove the usb cable of your orbicam from the pc and then unstall the software and then restart the pc and then reinstall the software [note: do not plug the usb unless it ask you or do not plug it untill the installation finish. after that plugin the usb cord and wait untill the driver install by your pc automatically. Hope it help!
^_^
3answers
My orbicam
The symptoms
The symptoms arise when a user double clicks on Acer Orbicam (Desktop icon), and Vista displays the following message: “Acer Orbicam application has stopped working” and needs to be shut down.
First of all, your webcam is still working, the device does not have problems. You can check this quite easily by opening Messenger -> Tools -> Webcam Settings.
Another way is to check the folder:
C:\windows\BisonCam\
There you will find the application “LiveCam.exe”. Run this to check that the webcam device is working fine.
If you don’t have the “BisonCam” folder, this means that your webcam is a different model; I don’t yet have a complete list of all the devices and their relative folders but all notebooks and webcams have some folder so if you look hard enough you’ll find yours.
The problem
There appear to be two factors that can create this problem:
1] The Orbicam application needs the correct orbicam driver to work correctly;
Windows Vista has its own internal driver to install the device, naming it “Acer Orbicam” (great Windows!!) but in this way the application cannot find the correct driver, so Vista returns the error message.
2] If some pictures are present inside “My Pictures” folders, the Orbicam application will fail to start. It seems to be a Vista issue and still needs to be fully clarified.
The problem seems to have been caused by the Vista Upgrade software, which causes the OrbiCam application on certain models to malfunction. However, as explained above, the OrbiCam camera works fine, the software just can’t control it correctly after the upgrade.
Another issue that has added to the confusion here is that there are “more than ten” different types of OrbiCams installed on Acer notebooks. Again as mentioned above Windows Vista has its own internal driver to install the device, and simply calls it “Acer Orbicam” which makes distinguishing the correct driver from wrong one an almost impossible task. If you replace your driver with the wrong one, the application cannot find the correct driver and you get the now famous error message.
Lastly, the problem is restricted to Vista-ready notebooks and NOT native Vista notebooks. By that I mean the problem does not exist with the new Gemstone and TravelMate ProFile models as these were designed specifically to run under Vista.
I know this is no consolation to users with this problem but I just wanted to reassure readers that this issue is not endemic to all Acer notebooks.
Solutions
Currently only 2 notebooks have complete solutions available online. This is because - so far - they are the only “problems” Acer support technicians in Taiwan have been able to fully replicate, analyse and repair.
These “fixes” are not general solutions and ARE NOT OK FOR ALL NOTEBOOKS. This explains why some readers have been getting error messages with the new drivers/applications. The new drivers and applications can be found at the following addresses:
Aspire 9300 at the following link:
Aspire 5570 at the following link:
http://support.acer-euro.com/drivers/notebook/as_5570.html
If your notebook is not one of the two above, read on:
For all notebooks with Acer Orbicam the repair procedure is the same:
1] identify the specific webcam device you have inside your notebook
2] get the hardware description (hardware id) of your notebook’s webcam
3] get the full serial number of your notebook (long alphanumeric code in the bottom side)
4] send this information to your local support centre who can then walk you through the procedure for your specific notebook.
All steps are important because only with the above information can Acer correctly identify the right driver and application for your notebook. Simply sending “Acer Orbicam” as the description, does not help because all the different webcams Acer installed are called “Acer Orbicam” (again, thanks Windows)…
So how do you identify the right one ?
How to get the webcam device information:
Go to “Control Panel”, switch to “Classic View” (the support team still find this way easier and better to work with than the default one) and double click on the “System” icon; to the right you will find Tasks list and below “Device Manager”, click on this.
Now you have the full list of devices of your notebook, look for “Imaging Devices” and double click on this. Here you will find the Acer Orbicam.
542506847_38185ec1b4_o.jpg Double click on “Acer Orbicam” and the Acer Orbicam Properties window appears. There are three tabs : General, Driver, Details
542397216_657b57f5d0_o.jpg Click on “Driver” tab, the important information listed here is:
“Driver Provider” and “Driver Version”
542506947_d280ed5924_o.jpg Copy this info onto a word / txt file or take a screenshot of this window. Just make sure you write down this information. Then click on “Details” tab
542506971_0b3e8f0f00_o.jpg Under “Property” you have a scrolling list, click on it and open the drop down menu.
542507017_6f244cf125_o.jpg On the drop down menu look for “Hardware Ids”. Click on this.
In the Value box, you should find something similar to:
USB\VID_5986&PID_0102&REV_0100&MI_00
USB\VID_5986&PID_0102&MI_00
542397338_1d8c1d1f3a_o.jpg As before, copy these two lines or make a “screenshot” of the window
At the end of all this you will have:
Your Notebook’s Serial Number
The OrbiCam Driver Provider
The OrbiCam Driver Version
The OrbiCam Hardware IDs
Send all of this information to Acer with your support request/telephone call. This should cut down the time it takes them to get you back up and running.
Good Luck, should get your cam going again/Please dont for get to Vote, Thank You.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
