SK Hand Tool (87018F) 9pc. Fractional Combination Wrench Set with Sure Grip Locking Wrench Rack Logo
Posted on Sep 15, 2009
Change combination on a presto lock on a briefcase
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
14506
Points
15
Enter the correct code and open the case. Now push the button you use to open the case to the open position and hold it there, now push in the clamp and push the opener more and it will lock in place. Enter the new code and push the clamp part again to set it. Do to other side now.
Anonymous
Level 1:
  • Posted on Dec 26, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
16659
Points
11
While case is open feel for a small slide switch on the back of lock on the inside of case. Now slide it to the left or right and hold while you set the numbers starting with the left and working to the right. Let the slide switch go and slide the latch lever to see if it will open. If so then you have change the lock settings.
Where can I get briefcase combination lock?
Look for my tip on unlocking luggage with combination locks.
Fix my briefcase combination lock
Use Combination To Release Button--Factory is 00
Set combination lock
Step 1:
Locate the reset button, usually placed to the side of the combination dials.
Step 2:
Press the reset button and hold it while rotating the number dials to the desired combination.
Step 3:
Release the reset button after you set the numbers to the new combination.
Try that :)
1helpful
Is there an owner's manual available on line for a Stebco Attache Case Model P-16? I need to know how to set the combinations on the dial lock system.
I couldn't find the manual for your particular briefcase, but please read the instructions on the attached link. It should help you since most briefcase combination locks work the same. Hope it helps.
How to Change the Lock Combination on Briefcase
Presto combination lock
By frequently resetting your lock combination, you decrease the chance that someone will break into your luggage.
If someone watches you open your luggage at baggage claim while going through security or at a hotel, they may break into your luggage when they encounter you on another leg of your journey.
Change your lock after every major flight or trip to help keep your items safe.
Avoid easy to guess passwords, as well, such as sequential numbers, all the same number or birthdays.
Open your lock by inputting the current combination.
New Prestolocks have a factory set combination of "0-0-0."
Turn the shackle 180 degrees.
Press the shackle down and turn it 90 degrees to the left or right.
Input the new combination.
Move the shackle 90 degrees so that it is 180 degrees from its locked position.
Take your hand off the shackle and pull it out.
Turn it back to the locked position.
Push the shackle into the lock and turn at least one of the lock's dials.
Write down your new combination.
Keep this paper in a safe place for future reference.
1helpful
Forgot my Presto Lock combination!
You cannot reset the lock unless you know the combination. You would need someone to pick the lock, like a locksmith and then once it's open you can reset the lock with a new combination.
I need to reset my combination on a pilot leather case
This is how you generally change the combo on a briefcase
1. With the briefcase closed put int the combination
2. Slide the bottons in the opposite direction than you usally do to open it.
3. Now set your new password.
4. Slide the buttons back into place.
5. If it dosent work the first time try it a few times
6. If it fails try reposting with more specific model information about your briefcase
How do you set your own combination for the locks on the briefcase,there were no instructions with the case
  • 1 Turn the lock to the correct combination and open the briefcase.
  • 2 Look at the lock. There should be one or two pins that you can slide with your fingers. If there is one, simply push it in. If there are two, push them together. It may be the same button you use to open the case.
  • 3 Change the lock to an easy-to-remember value, such as 000 or 123, to test the lock. Release the pin.
  • 4 Close the briefcase and turn the lock to another value. It should not open. Now turn it to the test combination. It should open right up.
  • 5 Repeat Steps 2 and 3, but this time choose a number that will be easy for you to remember, but hard for someone else to guess. Write down your new combination and keep it somewhere safe.
  • 3helpful
    I need to put a new combination on my briefcase. It has one combination in the middle
    When you open the briefcase on the inside to the right of where the combination is in the center there is a metal lever sticking out.
    Push this lever to the left and hold it there while you change the combination numbers.
    When you let the lever spring back to it's normal position, the numbers set will be the new combination.
    Top SK Hand Tools Experts
    john h
    goneforever.
    Ziyaad Khan
    Ziyaad Khan
    Level 1 Expert
    Are you a SK Hand Tool Expert? Answer questions, earn points and help others
