Car Audio & Video Logo
Anonymous Posted on Sep 15, 2009
2006 dodge ram navigation
The navigation fails to load the disk. do you know the problem? or has the manufacturer put a two year restriction on the disc to make you buy a new one for $200. Is there a fix to this
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1168
Points
Not from this site they will not tell me to do anything against the law. as in a burned copy or a loophale to just make it work. these people will only tell me where to buy it
Testimonial: "this was helpful"
2006 Dodge Ram 1500 5.7 4x4. What fuse runs the 4x4 please?
It isn't specified. There is more than one fuse that covers transmission. You would need an auto electrician or a transmission expert to connect a pro grade scan tool computer and diagnose if the switch or solenoid is faulty. A scan tool at this level is bi-directional and can command solenoids to operate and confirm that they do.
https://www.google.com/search?q=auto+electrician+near+me
Fuse Box Diagram Dodge Ram 1500/2500 (2002-2009)
https://fuse-box.info > dodge > dodge-ram-1500-2500-...
Fuse box diagram (location and assignment of electrical fuses) for Dodge Ram / Ram Pickup 1500/2500 (2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009).
2006-2009 Dodge Ram 1500/2500/3500 Fuse Box Diagram
https://knigaproavto.ru > ... > Dodge > Ram (Pickup)
Nov 16, 2018 - 2006-2009 Dodge Ram 1500/2500/3500 Fuse Box Diagram ; 5, 20, except Base: Sunroof ; 6, 40, Diesel ('06): Wastegate Solenoid, Drive Fan Radiator ; 6 ...
2006 5.7 ram 1500 fuse box diagram - DodgeForum.com
https://dodgeforum.com > ... > 3rd Gen Ram Tech
3rd Gen Ram Tech - 2006 5.7 ram 1500 fuse box diagram - I was hoping somebody had a fusebox diagram kicking around. The inside of my fuse box cover does not ...
Fuses and relay Dodge Ram 2002-2008
https://fusesdiagram.com > Dodge
Mar 27, 2017 - For Dodge Ram 1500, Dodge Ram 2500, Dodge Ram 3500 - 2002, 2003, 2004, 2005, 2006, 2007, 2008 model year. Cigarette lighter fuse - Fuse box in ..
2006 Dodge Ram not accelerating.
It's a guess, but the Throttle Body and Injection system needs to go through a re-learn process.
https://www.google.com/search?q=2006+dodge+ram+1500+5.7+hemi+throttle+body+relearn
1helpful
I have been 49 Dodge Ram pickup Barberton all the gauges in the lights and wipers going on and off on and off and everything else but her uncle Kate what would be the problem
2006 Dodge Ram Tachometer fix - YouTube
? 6:24
https://www.youtube.com/watch?v=ufQ1t4eOwkM
Aug 8, 2013 - Uploaded by Marc Reiter
I've been putting up with my inaccurate tach on my 2006 Ram for a couple years. ... 22:49. International dash gauge cluster fix this is a how to video dont ... 2006 Dodge Ram Truck Tachometer RPM gauge repair service ... Installation of a Trailer Brake Controller on a 2006 Dodge Ram Pickup - etrailer.com ...Missing: barberton ‎el
Dodge Ram Cruise Control Fix - YouTube
? 8:44
www.youtube.com/watch?v=ppcUyQZ14AE
Jan 5, 2011 - Uploaded by Axidias79
Here is how to fix the cruise on the vacuum actuated dodge ramcruise controls. I think they did that from 94-01 ...Missing: barberton ‎fluctuates
1helpful
Where is the low pressure switch on my 2006 Dodge Ram Diesel
The low pressure switch would be around the air dyer system.
If line drier is cool on one side and warm on other you have a line restriction. Is compressor cycling on and off.?.. be careful jumping low pressure switch...The high pressure on low side is restriction going to evaporator coil in firewall... check for a filter in cab for evaporator coil it may be stopped up
1helpful
Buying a used 2006 navigator. i was wondering if it is possible to update the navigation? and how you would recomend doing it? thanks
Yes and you may not buy the car if you know. But all of the Manufacturers probably operate the same scam. Even if you are the original owner, it costs you between $250 and $350 to get a reprogramming disk to upgrade the system. You simply use the cd and insert the Navigation disk, that disk stays in the cd when you have a multiple cd unit.
We leased a new Lincoln for 3 years and after 2 years a letter came out trying to sell us the upgrade. We did not upgrade, and felt we should have a current map for the remaining year of our lease as we felt we paid for the ability of the Navigation system to do its job the full 3 years. They did not give us an upgrade.
So at 2 year intervals, the Manufacturers will sock you with a $350 bill to keep your Navigation current. Or just use the old maps.
1helpful
2006 ram - restricted air flow. where are the
If your talking about no air flow, at the vents, floor,defrost, there are no doors that will restrict air flow, then you have a plugged Ac evaporater core, with foriegn matter, leaves, dirt, and oil from the ac itself, leak in evap leak cause this, as long as the blower is working on all speeds, remove the motor for inspection and evap , an other way to inspect the evap, remove the evap sensor grommet, look inside of hvac, the core will be plugged, this is an expesive repair to do. GOOD LUCK. RDJRP
2helpful
2answers
2006 Dodge Ram 1500 4.7 misfire
Dodge recommends new plugs at 60k. If that engine, I don't remember off hand, has a coil pack over overy plug, try switching the coil to a different plug and see if the missfire moves. If it does then you need a coil, if it doesnt then its the plug.
17helpful
2answers
2006 REC navigation radio (screen goes blank)
The same thing happens with my 2005 Jeep.
16helpful
Time clock change on dodge ram navigation radio
Press "NAV" to go to the main navigation menu.
Scroll down and select "System Settings"
Scroll down and select "Clock Setting"
Make sure "Show GPS Clock" is selected with a red check in the box.
I had to switch "Daylight Savings" from "ON" to "OFF" in order to bring the time back an hour. I assume that I'll just have to switch it back to "ON" in the Spring in order to move the time forward and hour.
Navigation
I am just guessing, but it sounds like whoever traded the car in might have given you a disc that wasn't for your particular vehicle??? I ordered a disc online, thinking I had the right one... and it read Disc Error as well when inserted. However, when I got the part# right, the new disc worked like a charm.
Also, when I bought my Charger... the dealership told me that it is not uncommon for the former owner to switch out discs before they trade the car in. I would call your dealer and read the number off the disc to them... so that they can check it to be sure that it is one that should be compatible with your year/make/model before I went any further.
Top Dakota Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Dakota Car Audio and Video Expert? Answer questions, earn points and help others
