Question about Apex Digital GB5108 51" Rear Projection EDTV-Ready Television
My Apex GB43HD10 pictures disappears after a while, sound works.
My picture goes out...but a light tap on either side of the TV will make it work. Any suggestions?
    Problem Solver:
  • 6 Answers
Possible solder connection in the powersupply needs to be
resolderd it shouldnt cost much
Posted on Oct 04, 2009
How to change a bulb in a apex pf2720 tv
I'd guess it is not a bulb issue if the audio also stopped working. Check your input source, connections and the like. Try using a different input (ie input 4 or the front AV connectors) and a different source (ie your old Nintendo instead of your DVD player).
Nov 17, 2011 | Apex Digital PF2720 27" TV
Apex Mod# GB43HD10 The picture is now blurry or wavy.
Sounds Like your convergence ICs big black ICs will part number on them example STK394-020 Call Mats for Parts on ICs 1-800-628-1118 Also Call Encompass you can order whole Board if you want to you just unplug old board and plug in new 1-800-638-3328
Oct 01, 2009 | Apex Digital GB43HD09 43" Rear Projection...
I have a Toshiba cx35e70 tv. The problem began as a turn on, live screen, no channels, no sound. I found that when I would tap on the tuner on the main board the problem would disappear. Every thing worked...
Is the VCR going through ch 3 or video inputs - if video inputs your TV tuner is likely bad if through ch 3 seeif te picture goes funny on ch 3 without using the VCR the tuner may be bad on higher band channels - smetimes you can remove the tuner and resolder the tuner itself. But if it always works with the VCR just use it that way and don't bother with the fix.
Sep 26, 2009 | Televison & Video
No picture on it.just went out or off
thecnical problem may be it a fuse on the main board or power supply.
Sep 04, 2009 | Apex Digital GB43HD09 43" Rear Projection...
Apex Digital GB43HD10
I was watching My Apex Digital GB43HD10 one night and i smelled smoke the TV went blank i lost all power, i called the repair man and he came and looked at it and replaced the thermosat and it solved the problem.
Oct 20, 2008 | Apex Digital GB4308 43" Rear Projection...
No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
Aug 25, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Rear Projection TV
I have the same set, about a year into owning it went black, power light but no picture, still under warrenty and ended up being the main board, they replaced and has worked well since, these tvs are sensative to spikes over the cable line, I got a really good cable surge protector after it was fixed.
Oct 11, 2007 | Televison & Video
Picture and sound disappeared
your red crt bulb is starting to go bad. somtimes you can tap lightly on the neck of the red and the prob. usually short term will go away. if not tube replacement is necessary. this is sometime a pricey repair. but worth it! john
Sep 08, 2007 | Akai PT4298HD Rear Projection Television
KV-32S45 Disappearing Picture, Good Sound
yes you have a bad vertical ic . i,ve seen bad conections on this ic too, it may not need to be replace its a ic that stands up 6 pins the numbeer on it starts with TDA
Apr 19, 2007 | Sony KV-32S45 32" TV
GB43HD10 PROBLEM
The circuit board on the right hand side is either cracked or the soldering came loose, I took mine apart and found it by mistake, everytime I pulled up the board i had picture again, so I propped up the board with some dumb-dumb and it has still been working, there are no parts for this TV
Mar 10, 2007 | Apex Digital GB43HD09 43" Rear Projection...
Apex Digital GB5108 51" Rear Projection EDTV-Ready Television Logo
129 people viewed this question
Top Apex Digital Televison & Video Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
