The jets are ajustable, by turning the center or outer ring of the jet to the left or right you will open or close the pressure to the jet. I hope this helps.
A weak pool jet is one of the most frequent problems for pool owners. If you ask a pool professional “Why are my pool jets not working?”, you may receive a blank stare and a pause. This reaction is due to the fact that we know the solution could be simple, but narrowing it down is time-consuming. We’ll separate the cause of low pool jet pressure into two parts. This will hopefully save you time from reading a section that doesn’t pertain to your situation. Part I will discuss low jet pressure when the filter gauge has a low PSI reading. In Part II we’ll discuss low jet pressure when the filter gauge has a high PSI reading.
Some air jet bubbler blowers are designed to run for 5 to 10 minutes after you drain the tub to push all of the water out of the air channels. It should shut off on its own once it senses all of the water has been blown out. If it continues to run much longer than that, then contact the mfg for a service call. You have a warranty if it is a recent purchase that should cover it. Hope this helps!
if your pump is surging then you do not have enough water in the bathtub or you have a jet that is blowing air into the suction fitting. this happens a lot when a jet faces the suction and the air control is wide open. the suction pulls in too much air and causes the pump cavitation (surging). Try pointing the jet opposite the suction cover upwards and see if that doesn't solve the problem.
This is an ether or situation. Most systems now are set up with three way valves and if you turn the jets on you will shut the pool returns down. If you turn the pool back on you will shut the spa jets off.
Try Guillens.com or usparts.com I have had some good luck finnding jets. Maax is still in business and you might be able to get the jet directly from them, although they are in Canada. Hope this helps.
