Question about Air Supply Captive Aire ND-PSP-18SS Exhaust Hood with Front
I need a diagram for how to connect the wiring parts for a commercial exhaust hood the hoods mark are LARKIN mark and the other one is CAPTIVEAIRE 1 of the hoods is 4 ft and the other 1 is 8 ft
Posted by angelita4u on
Anonymous
Google exhaust hood micro switch there are several diagrams.You want the exhaust to turn on and the make up air.electricial under the hood and the gas to turn off.
Posted on Sep 17, 2009
Where is the oxygen sensor relay located in my 2005 dodge durango?
An oxygen sensor - sometimes called a 'Lambda sensor' - will be located on the exhaust pipe somewhere between the exhaust manifold but before the catalytic converter.
Just look under the car/under the hood for something that screws into the exhaust pipe. It'll have 1 or more electrical wires attached
Feb 10, 2016 | 2005 Dodge Durango Limited
Sudden death of the range hood
Did you measure the continuity of the primary and secondaries of the transformer which drops the line voltage to supply the front panel? Any chance you could scan and post the "mini-manual" that comes inside the unit? I repair just about any kind of control board / system out there, in case you might be interested. My listing is here on FixYa: http://tinyurl.com/yzjozk
Jun 04, 2007 | GE ZV950SDSS Kitchen Hood
Wiring for a Dayton motor 6k857L
Wiring diagram appears on side of motor.
This motor is rated 115Volt.
Hot and Neutral wires connect to main terminals.
Connect other wires as shown on label.
For example there can be yellow, black, blue and white wires.
Dayton manufacturing is owned by WW Grainger.
Contact Grainger.
http://www.grainger.com/Grainger/static/help_contactus.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 12, 2012 | Dryers
Cooker hood installation
A cooker hood needs to done by a competent qualified Electrician but basically depending on your surface of the cooker hood.Depending on the type of cooker hood you have(extract or outside) If it is a extraction (meaning you are using filters and not connected to a vent) The Electrician needs to connect the electric to a point or spur via a power switch on the wall which when you fit up the main part of the hub covers the spur. after that you need to measure and fit the cooker hood to your requirements but make sure your walls can support it and mark off the holes before drilling or check the walls for electric wires in terms of safety.
May 21, 2012 | Washing Machines
How do you replace?
Kitchen hood replacement can be completed easily with a family member or a friend. While you may wonder why anyone would replace a kitchen hood, the answer usually is simple. Here is how to replace a kitchen hood.
Tools Needed
  • New Range/Kitchen Hood
  • Screws
  • Screwdriver
  • Friend
  • Wiring Nuts
  • Circuit Tester
Warning: Remember that you are dealing with electricity, so stay away from water and use all safety precautions issued by the manufacturer.
Step 1 - Shut off Electricity
Remember to turn off the electrical supply to the old kitchen hood. You will need to do this via the circuit breaker box. Wait for 10 to 20 minutes and then test the wires with the circuit tester to double check that no electricity is being supplied to the kitchen hood.
Step 2 - Remove Old Hood
After you know for a fact that it is not receiving an electrical current, you can begin the process of removing the older kitchen hood. You should first take off the electrical wiring cover that is located by the light fixture. Then have your family member or friend hold up the old kitchen hood while you remove any screws or bolts from it. Once that is done, you can then freely slide it off.
Step 3 - Check Wiring
Double check that you have at least 12 inches of wiring to connect your kitchen hood to the wall. It should be noted that if you have a kitchen hood without vents, proceed to step 5 next.
Step 4 - Find the Ducts
If your new kitchen hood has vents, you will need to locate the fan or vent duct. Once you have found it, you can open up the vent hole where it will belong.
Step 5 - Wires
Open up the covering for the wiring and put the covering in a safe area for easy reach.
Step 6 - Install the New Kitchen Hood
Have your friend or family member hold up the kitchen hood and mark the areas where the screws or bolts will be. Then have them put down the kitchen hood and screw in the screws half way into the holes. After that, you can slide in the kitchen hood.
Step 7 - Route Wiring
Lightly pull the wiring through the proper holes and connect both black wires from the new kitchen hood to the black wire from the wall with a wire nut. Then connect the two white wires from the hood with the white wire from the wall, again using a wire nut. Next, connect the green wire to the green ground screw. Then place the wire covering back on.
Step 8 - Tighten Screws
Finish tightening the screws in place.
Step 9 - Test
Check to make sure the fan and light work. If it is supposed to vent outside, make sure that the air is leaving the vent with no issues. If something does not work proper, repeat steps 6 and 7 until everything works well. Remember that you will be working with electrical equipment, so follow safety measures issued by the state or the city.
Jan 29, 2011 | Kobe RA9436SQB Kitchen Hood
Need a under hood wiring diagram for a 1995 geo metro
if you are looking for a diagram that shows wires under the hood you are out of luck, a wiring diagram looks like a schematic, pages
of lines like a grid with abbreviations.but you won't find one that shows wire locations, sorry, you can probably get a parts store to copy schematics for you, or go to chilton on demand
Aug 19, 2010 | Geo Metro Cars & Trucks
Can this be installed over an island?
Bring a focal point to your kitchen by having an island range hood, combining function and elegant form. A suspended hood is also an efficient way to vent
grease, odors and smoke to the outside from a island stovetop while you cook. You can install an island range hood in just a few hours with the right tools
and knowledge.
1.Wear safety glasses and work gloves. Turn off the electricity to your kitchen at the circuit panel. Cover the circuit breaker with a piece of electrical
tape to prevent people from turning the on switch while you are at work.
2.Lay work drop cloths on your cooktop and floor to catch dust and debris. Mark the duct opening with a pencil in the ceiling, where the island hood will be
installed. Be sure the opening is centered directly above your cooktop. Cut the opening using a hacksaw.
3.Go up to the roof, using a cat's claw and hammer to remove stucco, tiles, sheathing and insulation to make way for the steel venting duct. Drop a
plumb bob down the roof, making sure the line is straight down for the ductwork.
4.Follow the manufacturer's instructions for locations, installing 2-by-2 wooden blocks in the ceiling to hold the ductwork hangers.
5.Install the venting duct from the outside of the home, down to the location of the exhaust vents on the island hood. The ducts should easily slip into each
other. Secure all the duct sections with duct sealing putty, using a putty knife.
6.Screw a roof cap on the end of the duct at the roof. Seal any openings or gaps where the roof, ceiling and duct meet with silicon sealant. Let the sealant
dry, then paint with colors matched to the surrounds.
7.Place your hood upside-down on the floor, with the fan and filter facing upward. Locate and unscrew the metal electrical box cover on the island range
hood, to expose the wiring
8.Install the hood cover to the load-bearing ceiling frame with the package hardware through the four inside mounting corner flanges on the cover.
9.Measure what will be the distance from the bottom of your hood to the cooktop; it should not exceed 30 inches for exhaust efficiency. Have a helper hold
the hood in place while you attach the hood on the hood cover using the included screws. Use a level be sure the hood is level as mounted.
10.Connect the electrical wiring by consulting the manufacturer's suggestions or hire an electrician if you are not familiar with house wiring. Tuck the wires neatly in the hood electrical box and then replace the cover, after connecting the hood wires to the wall wiring.
11.Remove the electrical tape on the circuit breaker, turn on the electricity to your kitchen and test your island range hood.
May 26, 2009 | KitchenAid KHVU781RSS Stainless Steel...
Wiring hookup
The 2 black wires on the hood go to the black from the wall. The 2 black on the hood is in case you want separate switches as 1 is for fan and 1 is for light. The green goes to the bare copper wire. Its the ground. And are you sure the wire is yellow? It should be white and connect to the other white. This is the neutral.
Mar 01, 2008 | Miele Designer DA230-2 Kitchen Hood
Kitchen Ranges Logo
833 people viewed this question
Top Air Supply Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you an Air Supply Kitchen Range Expert? Answer questions, earn points and help others
