Question about Furniture
If we have a power recliner by catnapped and the power goes out and we do not have a battery back up is there anyway we can get the chair to return to sitting position.
Posted by Valerie Mowbray on
5 Related Answers
gnshome
  • 31 Answers
SOURCE: Invacare power chair model #1089384;
Hope you have had this fixed by now. But in case not and you are not able to use the chair.
If the chair still drives it's not batteries. The toggle switch box should be ok if there is no visable damage to it. Bad connections of the wiring from the toggle switch box to power or the recline or tilt motor should be inspected. A electronic tech is needed for most electronic failures.
Posted on Apr 07, 2011
diodeic
SANYADE OMOTOLA
  • 1622 Answers
SOURCE: MY CHAIR IS IN THE RECLINING POSITION AND IT
The best thing to do in this situation is to call the vendor and have them repair it under warranty. There should be no charge for this service since the chair is brand new.
There are some checks you can make to avoid a service call. You have checked the batteries and hopefully the chair is plugged into the wall outlet. It is possible that something got disconnected under the chair. To check this you need to flip the chair over on its side or on its back since the leg rest scissor mechanism is extended. Look for any plugs that have come apart at their connections. Check for a pinched or binding scissor mechanism or tilt frame parts.
You should not attempt this at all if you cannot safely move a large piece of furniture. Perhaps a friend or relative may be able to help.
Insist that the vendor honor their warranty commitment ASAP. If you paid with a credit card, you should contact your credit card company to put the amount in dispute if the vendor is unresponsive. Hope this helps.
And you can troubleshoot with the below instructions if it with also help
things you'll need:
* Pride chair Owner's Manual
* Screwdriver
* Wrench
* Pliers
Instructions
Look at the chair's electrical plug, as the chair most likely became unplugged or the plug is not fully connected to the outlet. If this is the case, securely reconnect the plug.
Check the chair's connections. The electrical connections under the chair could be loose or connection cables could be pinched or bent. Tighten loose electrical connections with a small screwdriver and straighten bent or pinched cables.
Check the chair's transformer, motor and relay box under the chair as a malfunction in any of these could cause the chair to stop working completely. The hand control used by the operator to change the chair's position may also be malfunctioning.
Test the chair's wood frame, bolts and lift frame. Loose wood frames or bolts, overly tight bolts or the lift frame rubbing against the wood frame will all cause the chair to squeal.
Lay the chair on its side and check the wood frame and t-bracket. If the wood frame is rubbing against the lift frame or the t-bracket is cracking, you could hear popping noise. The t-bracket is the metal frame on the underside of the lift chair.
Check the dual motor timing if the chair will not recline all the way. The motors' timing could be off which would stop the chair from completely reclining. Put the chair on its side and remove the motor and plug it in. Use the hand control to turn the motor on and let it run until it stops on its own. Screw the push tube, located to the right of the drive tube where you just removed the motor, until you feel it bottoming out. Turn the push tube back two turns and grab the push tube. Turn the unit on with the hand control and allow the push tube to move away from the metal casing. Push the pin at the back of the push tube and reinstall the motor. This should re-time the motor.
Look at the wood frame, seat foam, leveling legs, motors and bolts if the chair is crooked. The wood frame could be twisted, the seat foam may be broken or misshapen, the leveling leg may need adjustment, the motor could be timed incorrectly or the bolts could be loose. If all looks in order, make sure the ground under the chair is level.
Unplug the chair before you begin fixing the chair.
Restore power to an inoperable lift chair. Ensure the circuit breaker box is connected to the electrical outlet. Make sure the external transformer is plugged directly into an electrical outlet.
Fix a Pride lift chair that only operates in one direction. Use a cotton swab to remove dust and debris from the toggle switch on the hand control. Flip the toggle switch back and forth to loosen any remaining debris which may be causing an obstruction.
Fix inoperable heat and massage features. Check the LED lights on the hand controls; the LED display is not lit, hand-tighten the connection between the hand control and the lift chair. Make sure the the heat and massage units are properly connected to the back of the lift chair.
Posted on May 02, 2011
Lissa Wied
  • 344 Answers
SOURCE: 2005 escalade passenger chair
Switch is shot probally
Posted on Nov 29, 2012
Ed Yeager
  • 3 Answers
SOURCE: I have a quantum 600
I'm having the same problem with the red light on my Q6000Z PC not going out, no matter what position that the seat is in. Yesterday I lifted the seat to change my furnice filter and when I lower the seat light wouldn't go out and the chait would not move. and yes I did try going up and down several times. I do have a Quantum joystick controler, but I don't know how to use it. Can anybody help me? Or at least give me a website name where I can go to fond out.
Posted on Dec 16, 2012
My wheelchair's green light doesn't come on after I return from my reclining position
Contact Pride for a manual, you'll need one. Or a Wheelchair/ medical equipment outfit.
Aug 02, 2014 | Pride Health & Beauty
Damaged goods
Sorry we do not have repair facilities.
Jul 21, 2017 | Comfort Products Relaxzen Deluxe Padded...
Jazzy chair yellow light on the power control continues to blink. will not turn off.
yes nplug battery charger in and wait till batterys asre fully charged and turn off,if it doesnt u got water or moisture in the joystick and need a new one
Jan 06, 2014 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Need to put a spring back on my lane furniture recliner and do not know where it goes
GO to the store where you purchased recliner and ask sales personal to help you turn over chair to see where part goes!
Sep 30, 2012 | Lane Furniture Lane Xander Zero-Gravity...
What exactly is a recliner? How is it different from other chairs?
A recliner is a type of chair that can tilt backward. They usually come with a built in foot rest that comes forward when the user tilts back. They have the ability to adjust from a slight incline to lying almost flat.
Aug 09, 2012 | Furniture
What are the different types of leather office chairs?
Leatheroffice chairs include: Adjustable Leather Task Chair, Executive Mesh Chair,high back traditional executive swivel chair, and leather plus posture taskchair. For more details on these chairs, go to this website: http://www.ehow.com/list_6105999_types-leather-office-chairs.html
Jul 30, 2012 | Furniture
Invacare power chair model #1089384; is stuck in the reclining position and won't come back up
Jan 18, 2011 | Invacare Health & Beauty
Furniture Logo
152 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
