Question about Samsung ML-1630 Laser Printer
Why is it showing fuser low heat error? - Samsung ML-1630 Laser Printer
Posted by Nate Keyman on
Why my canon ir 2318 display error code 03
Hi Daban this is Alex Walker expert to help you for Canon Printer Call +1(404)981-1535 I will be glad to assist you
Dec 29, 2015 | Canon Office Equipment & Supplies
Dell 1600n low heat error
Remove the fuser lamp and put it back in place, it is not heating properly.
Apr 02, 2008 | Dell 1600n All-In-One Laser Printer
I have the hpcolorlaserjet 9500n shows error code 50.6, how to solve
50.6 error is an open fuser heating circuit
between the fuser and low-voltage power supply.
Problem could be the fuser, the low voltage power supply
or the DC Controller.
The 1st thing to do is replace the fuser. If you have another one.
You should really call a printer tech to look at it.
Dec 16, 2010 | HP LaserJet 9500n Printer
PRINTER LOW HEAT ERROR
Low heat means either the fuser is not heating up or it is not sensed properly. you can find a new fuser at www.precisionroller.com but the low voltage power supply could be bad as well.
Oct 29, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Engine Fuser Low Heat Error
What this means is that the fuser is not reaching operating temperature. The most common reason for this failure is the xenon lamp inside the heat roller of the fuser has burned out. You can verify this by checking for continuity between the two contacts that connect to the lamp with an Ohm meter or digital multi meter.
If the continuity is good, the second most common reason for failure would be the LVPS, or low voltage power supply.
And last, although by far the least common reason for this error is the main logic board.
Have you checked to see if the unit is under warranty? If so, this would be a covered repair.
The part number for the fuser is listed below. Depending on your location and electrical system ( 110 or 220 )
ELA UNIT-FUSER 230V part number :JC96-03239A for use with 230V
ELA UNIT-FUSER 110V part number :JC96-03239B for use with 110V
Other then samsung, you can try a google search, and also an ebay search for the part number and find the best price for the item.
Good luck,
Cory
Nov 04, 2008 | Samsung CLP-510 Laser Printer
"Low Heat Error"
Thats probably the best way to solve the solution. Sometimes if there is a thermistor that is causing the problem that can be serviceable in the fuser unit, that can be replaced instead of purchasing a whole new fuser assembly. It's less expensive replacing the thermistor.
Jul 16, 2008 | Samsung CLP-600N Laser Printer
ENGINE FUSER, LOW HEAT ERROR
Replace the fuser, it's not reaching operating temperature within a set time (normally a thermister or the lamp is shot)
May 21, 2008 | Samsung ML-3561ND Laser Printer
Hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell [email protected]
Apr 21, 2008 | HP LaserJet 4350 Printer
Low heat error
Low Heat Error
Cycle Power
There is a problem
in the fuser unit.
Unplug the power
cord and plug it back
in. If the problem
persists, please call
for service.
If this doesnt work call the fuser unit needs to be replaced.
Nov 02, 2007 | Samsung CLX 3160fn All-In-One Printer
Basically the error message is telling you the printer cannot keep the fuser temperature at the proper temperature (too low). It could be a lot of things but typically it is due to a fuser assembly gone bad.
Feb 20, 2007 | Samsung ML-2551N Laser Printer
Samsung ML-1630 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
