Question about Camping, Backpacking & Hiking
Defiant flashlight HD15Q451 disassembly and replacement switch
Posted by joel gordon on
1 Related Answer
emissionwiz
Marvin
  • 85239 Answers
SOURCE: I dropped my Defiant 1000 lumen led flashlight it broke the switch/endcap I'm trying to get a replacement its the 3 D cell one has a high/low switch
Sorry we do not sell parts, if you can get the part it would need to come from the manufacturer or distributor, really doubt that they make replacement parts.
Posted on Nov 28, 2016
Nov 28, 2016 | Camping, Backpacking & Hiking
I have a defiant flashlight that has a flat chip type bulb. I need to get one for my flashlight
look up your model online or go to defiant site for location of distributor or replacement parts
Nov 12, 2016 | Camping, Backpacking & Hiking
Where Can I find batteries for defiant
It's a special premade pack so I don't think you can find a direct replacement however it does appear to be 6xAA batteries. Must be series parallel. 3 in series, two sets of 3 in parallel. If you are handy with a soldering iron you could replace it by making a new pack using NiMH AA cells.
Oct 07, 2014 | Camping, Backpacking & Hiking
Model 7000 slide not working
I have a Defiant 7000 flashlight and took a look. When the light is closed, the top of the battery door (1) is right at the lip (2) that keeps the light from over extending. I couldn't get mine to close with the cover loose, but if you did you could carefully drill a hole (3) in the outer casing to see and push the battery door back into place. You could also remove the two philips screws under the rotating magnets on the base and maybe push hard enough to force the top out?
Feb 22, 2014 | Defiant Camping, Backpacking & Hiking
Defiant headlamp; where's the tab to be removed?
If you are talking about a shipping tab that prevents the batteries from discharging during shipping, look inside the battery compartment.
There should be a plastic, or cardboard tab, that prevents one of the battery ends from make contact with the flashlight. Just pull the tab to remove it.
Mar 24, 2013 | Defiant Headlamps, Lanterns & Spotlights:...
I need to find a ac/dc charger for a Defiant Flashlight Model 800-2701D Can you help??
This flashlight is sold by Home Depot, and it is possible that you might be able to find a name-brand exact replacement charger there. However, you almost certainly can find a replacement charger elsewhere for less money.
Looking at a picture of the light and its power adapter, it appears that the light has a standard barrel charging port. A dollar store or "Dollar Plus" store is likely to sell inexpensive multi-voltage universal chargers that will fit this light and get you back in business for under $5.
When fitting a non-OEM charger to your light, make sure that you've set proper polarity and input voltage for your device, or else you may damage it in charging. Many devices specify voltage and polarity right on the device, molded into the case or on a small sticker. That makes this process super-easy. Otherwise, you may have to head down to a Home Depot and peek at one of these lights in its box to read the voltage output off the stock charger. The odds are pretty good that it'll be putting out 12 volts, but I won't guarantee that by any means--input may be 6v or even 4.5 volts, though those are much less common in lights of this type.
Dec 16, 2012 | Defiant Camping, Backpacking & Hiking
Camping, Backpacking & Hiking Logo
244 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Kardoc
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
