Question about Car Audio & Video
Greetings, may I know what is the code for the following Grundig radio SC 303 C NUMBER--GM 0303R1735442
Posted by Stoyanov on
3 Related Answers
xxxxxx xxx
  • 5013 Answers
SOURCE: lost code for grundig sc 303 car stereo from a
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
note: Unfortunately not all radios can be decoded using the Serial Number
If not then try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
Posted on Oct 02, 2009
xxxxxx xxx
  • 5013 Answers
SOURCE: Need code for Grundig SC
your code is 7283
Posted on Mar 30, 2011
xxxxxx xxx
  • 5013 Answers
SOURCE: I NEED RADIO CODE FOR GRUNDIG -=SC 303
your code is 1174
Posted on May 17, 2011
Grundig radio code
For all Grundig radio codes from the serial number contact this link: Car radio codes in Uxbridge London Gumtree
Feb 02, 2017 | Grundig Audio Players & Recorders
Hi, i am trying to get the code for my car radio in my vauxhall combo van, the radio is a grundig 200 PL. and all the info on the radio is: car 200 PL 19353 064 0 or D, cant quite make the last digit out....
If this vehicle is after year 2000 then the code is only available from your Main Dealer or a Radio Decode Service .
If pre year 2000 quote the 14 character Serial Number beginning with
GM ************ found engraved in the metal casing
Aug 23, 2010 | Car Audio & Video
Lost code for grundig sc 303 car stereo from a vauxhall astra?
Oct 02, 2009 | Car Audio & Video
Unlock code for grundig car 200 radio cassette
reset code for grundig car200 casette radio
Sep 02, 2009 | Vehicle Parts & Accessories
Safe mode on Grundig 200 car radio, do not know where to find serial number.
Grundig 200 car radio can decode in the next way:
First step: Switch off the radio and the ignition as well.
Second step: Push the AS button and keep it pushed, at the same time turn on the ignition.
After this you will hear a beep sound. Now you can release the AS button.
Now you can enter the code in the next way: The first number can be set with the button ''1'', the second number of your code can be set with button ''2'' and so on. By pushing the ''1'',''2'',3'',''4'' buttons the value indicated in the screen will be increased by one. So if the first number of your code is 5 then you have to push the button ''1'' 5 times.
if this doesnt work then it will be cheaper to buy a new car radio contact me and let me no how you get on :)
Oh and the serial number is either engraved on the side of the unit or an actual sticker which is in the format you describe. You'll need to remove the unit from the dashboard to be able to get access to this.
Apr 20, 2009 | Car Audio & Video
Grundig car radio codes
There are 3 ways you can get the radio code:
1. Reference your car manual or the Grundig's manual that came with the unit. Most times, there is a sticker on the manual with the radio code printed;
2. Call/visit the car dealer and explain your issue. You may need to show proof of ownership of the vehicle and/or the radio;
3. Use firms who specializes in this. You can try here, here or here.
If the Grundig is the original radio installed when the Vauxhall Astra was new. there are some unconfirmed reports that the radio code is also stenciled on the metal plate where the Vehicle Identification Number is.
Hope that this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Jan 22, 2008 | Car Audio & Video
Car Audio & Video Logo
112 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
