Question about Schlage Locks & Locksmithing
I moved my Schlage BE469 and after a factory reset it won't accept the default codes but just blinks red 3 times and locks up. Any suggestions???
Posted by Ayodele Adeboye on
5 Related Answers
Anonymous
SOURCE: Forgot Lock Code - Samsung m500 Cell Phone
try to use last 4 digit of your phone number . go into the menu then setting then security then enter four digets and you can find these 4 degits into in setting then phone info enjoyyyyyyyyyyyyyy
Posted on Jun 05, 2009
Anonymous
  • 59 Answers
SOURCE: I have the same kind of problem
Restore the lock first
1.disconnect battery
2.press and release the SCHLAGE button
3.reconnect the bat and wait until SCHLAGE is no longer lit.
4. within 10 sec,press and hold SCHLAGE until SCHLAGE lights green and the lock beeps.
The lock is back to factory now.
Now add your user code.
Adding a new user code
DPC is-digit programming code
DUC is digit user code
Yellow sticker has factory 6 digit programming and 4 digit user code on it.
1. 6DPC push SCHLAGE, push 1, enter 4DUC twice.
this lock will only take 2 user codes.
Hope this helps. Leave feedback for others if it helps
Posted on Aug 30, 2009
Testimonial: "Yes this did the trick. I changed the programming code so long ago I could not remember it. "
Anonymous
SOURCE: how to reset nokia 2630 to factory default
MY NOKIA 2630 IS JUST SUDDENLY ASKING FOR A SECURITY CODE & I HAVE NEVER HAD A SECURITY CODE
Posted on Sep 11, 2009
Anonymous
SOURCE: Ming Xing a008 factory phone lock code??
1122
Posted on Nov 06, 2009
Anonymous
SOURCE: Acer projector P3150 locked with passwd
Read some Acer manual and it says:
Administrator Password
The "Administrator Password" can be used in both the "Enter
Administrator Password" and "Enter Password" dialog boxes.
• Press "Play" to change the "Administrator Password".
• The factory default of "Administrator Password" is "1234".
If you forgot your administrator password, do the following to
retrieve the administrator password:
• An unique 6-digit "Universal Password" which is printed on
the Security Card (please check accessory in the box). This
unique password is the number which will be accepted by
projector anytime no matter what the Administrator
Password is.
• If losing this security card and number, please contact with an
Acer service center.
Posted on Jan 29, 2010
My schlage keypad will not do anything anymore i even tried new batteries has happened on all three of my locks
Probably need to be reset to factory default. Since it is all your locks you probably change all the batteries same time.
provided link to Schlage
http://www.schlage.com/en/home/contact-us.html
Oct 01, 2016 | Schlage Deadbolt. Century Satin Nickel...
Programming code will not work
I work for factorylocks.com. We get programing questions all the time for Schlage FE575/595. The factory default programming code and PIN codes are on a sticker stuck to the inside of the front housing of the lock. You will need to take the lock off of the door to see this sticker. Once you have done so, reset the lock back to the factory defaults and reprogram the locks to your settings using the programming instructions you can find here http://www.youtube.com/watch?v=z8BgHP712eg
Feb 03, 2013 | Schlage FE595 Plymouth Electronic Keypad...
Schlage keyless lock lost 6 digit code and no sticker inside either
You will need to take the keypad look off of your
door and record the 6 digit programming code and the two factory
default PIN codes. You then need to perform the factory reset to
erase any codes and restore the lock back to the factory defaults.
This procedure is outlined, as well as the programming of the device, in the attached instructions.
http://www.factorylocks.com/PDFs/Programming%20Instructions.pdf
Regards,
Leslie
Factorylocks.com
877-345-6257 (877-34-LOCKS)
Jan 13, 2013 | Schlage FE595 Plymouth Electronic Keypad...
How do you unlock a red blinking camelot schlage Lock?
i would remove the inside half and take the battery out or reset if there is a reset button
Jan 01, 2013 | SCHLAGE LOCK COMPANY Schlage BE365VPLY505...
What is the factory default code for a Schlage Cobra Lock
There is no '"factory default code". Sorry.
Try Schlage.com
Feb 13, 2012 | Locks & Locksmithing
Schlage cobra default code
There is no "factory default code". If there was such a thing, you could bet that any good thief would have it-rendering your lock useless as a security device.
Try Schlage.com for further information.
Feb 13, 2012 | Schlage COBRA by Keyless Lock
I can't put in the 6-digit PC to my new BE365 Schlage. When the lock is idle, I put in the 6-digit code and the lock thinks I'm putting in the 4-digit UC, so it errors out. My 2 default UC codes...
I don't have a direct answer, but here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
BE-365 installation & programming PDF: http://consumer.schlage.com/Project%20Documents/P515-858.pdf
Jun 03, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
I have the same kind of problem. I have the programming code, but when I enter it, after entering the 4 th digit the lock blinks an error thinking I entered an incorrect user code?? So I think I might have...
Aug 30, 2009 | Schlage BE365-PLY BE365PLY626 Satin...
Locks & Locksmithing Logo
175 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
