Question about Kenmore Dishwashers
My kenmore dishwasher model 665.13599k600 will not turn on.. verified power to control board
Posted by Jaime Martinez on
Tom Chichester
    Top Expert:
  • Kenmore Master
  • 62,198 Answers
Could be a defective cycle timer
Posted on Dec 03, 2020
5 Related Answers
Anonymous
SOURCE: the control lock on button will not go off
I've tried the NOHEAT button but I just get a few blinks on the lock light and the problem persists.
Any Ideas?
Posted on Sep 14, 2008
Anonymous
  • 949 Answers
SOURCE: We replaced the heating element and control board
Hi Paul,
First off check to make sure you have incoming power, that the circuit breaker is not tripped or fuse blown, the outlet it is connected to has power, no switch that controls that is off.
If power is going to the dishwasher the most common reason for the unit to be dead like this would be the thermal fuse. The thermal fuse is a device that clips on to the control board you just replaced. It senses the temperature of the board and trips if it gets too hot. My guess is that it either is not clipped on to the new board in the right spot or one of the wire connections to the board or this fuse is not tight and creating enough heat to trip it.
You will need to replace this fuse if it is bad, it will come with new wires for it. Be sure to install the new wires, the kit will have instructions.
Posted on Apr 25, 2010
SOURCE: Trying to verify manufacture date for Kenmore
Niðurstöður 1 - 1 af 1 fyrir Kenmore Precision Quite Guard model no 587.15262900. (0,07 sekúndur)
Try that link Niðurstöður
  1. Trying to verify manufacture date for Kenmore - FixYa 16 Jun 2010 ... Trying to verify manufacture date for Kenmore Precision Quite Guard dishwasher with Model No 587.15262900 and serial No TH93845362 ...
    www.fixya.com/.../t5103865-trying_verify_manufacture_date_kenmore -
Posted on Jun 17, 2010
Anonymous
SOURCE: Kenmore ultra wash dishwasher control lock light flashing
Just press the 'Air Dry' button for 5-6 seconds....I have an ancient Kenmore Dishwasher (ULTRA)
Posted on Dec 13, 2010
ginko
Ginko
  • 19396 Answers
SOURCE: GE profile PDW9280J00SS dishwasher. Dishwasher shows
Hi.
You said that there is power to the board. Be sure that there is volts in there, otherwise check power cord (test continuity rather than volts-it is safer and faster).
Check the door switch. If the door switch is faulty, then the dishwasher will not start the cycle. The door switch can be tested in a number of ways. One way is by jumping the switch and cycling, this is easier than reading Ohms or Volts while operating the switch.
Here all parts and diagrams for this model.
Regards.
Ginko.
Posted on Mar 05, 2011
How do I fix a flashing Start/Resume light on a Kenmore Elite dishwasher model 665.13793K601?
These dishwashers are known to accumulate moisture in the keypad and then short. The solution that I have seen is to replace the keypad...It is possible that all of your issues with this dishwasher could point back to the keypad. After spending $$$ on the circuit boards, do you want to throw and additional $135 for a keypad? or replace the whole unit? Food for thought. Here is a link for you:
http://www.repairclinic.com/PartDetail/Control-Panel/8572855/1180767?modelNumber=665.13793K601?RCAID=1000065
Kenmore dishwasher
Kenmore appliances are made by many different manufactures and depend on manufacture there are variety of resetting procedure
In some models If turn off your main power to dishwasher for one hour or so and then turn it back on. It should reset itself other wise it seems like it is in need of new control board
Dec 09, 2013 • Dishwashers
1helpful
Lights do not come on kenmore elite dishwasher
There is a thermal fuse on this model located on the control board. Remove control panel and you will see it attached to the board with 2 wires going to it. part number is 8193762. Hope this helps.
Feb 24, 2010 • Dishwashers
3helpful
Kenmore dishwasher model#66513582R-700 with no power.
Fuse does not protect against high voltage. Most likely burned up the control board
1helpful
Dishwasher not filling
Yes you should have 120v to the valve so the problem is elsewhere. Possibly the control isn't sending the proper voltage but you will need a tech to verify as this board is about $130
http://tclaundryrepair.com/
2answers
Model#665.15829000 kenmore
sounds like you have a stuck key pad on the touch control board. there is no easy way to check this, but you can unplug the "ribbon" strip from the control board. then you will need to jumper the board to see if you can force the unit to run by bypassing the key pad.
i cant find an exact match for your model number, but if you check the wiring diagram, behind the lower access panel, it will show you which 2 terminals can turn on a cycle.
the best thing i can tell you is to just replace the control panel with a touch pad assembly. it could cost about 125-150 bucks, but that should fix the problem.
Kenmore dishwasher on power
Yes teake the control panel down attached to the control board ios a fuse test it. usually it is a white square thing attached to the front right of the control board. if it is not white it is round black and silver
Dishwashers Logo
Top Kenmore Dishwashers Experts
Paul Carew
Vernon Taylor
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
