How do I program my rona facto lock
For Facto, remove the screw on the inside of the door on the door lock to get to the inner portion where you program
NB : in order to change the lock code, the chime feature has to be on (3rd little button on right bottom) or it will not change.
Make sure the chime is on.
Press the program button once and when it beeps, change the code on the outside keypad and press lock. (I suggest you test it before actually closing the door by hitting the lock button. The lock barrel should come out, as if you had locked the door. Hit the lock button on the keypad and key in the new number. The barrel should return inside as if you had opened the door. If not, it did not program the new number. Try programming again.).
Press the program button twice to change the second code and when it beeps, change the code on the outside keypad and press the lock. (Again, I suggest you test)
Apr 30, 2014 |
Locks & Locksmithing
