SOURCE: SanDisk Micro SD Card problems.
the card needs to be formated on n73.
if still not work than the card is faulty
SOURCE: SONY DCS T1 FORMAT ERROR C:13:01
Hi.. I think you have solved the problem yourself... replace the adapter with a memory stick... You have eliminated the micro sd card as bad... now try a new known good memory stick..
Thanks
jim
SOURCE: how much of GB micro SD card does htc tytn-2 support ?
technically speaking 32 Gb is the limit but the only size Max that is available is 8Gb Type is MICRO SDHC and Sandisk or Kingston both are good brands PLS RATE ME FIXYA FOR HELP
see this on EBAY
http://cgi.ebay.com.au/8-GB-SanDisk-microSD-HC-fits-HTC-Touch-TyTN-ii-S710-8GB_W0QQitemZ380108918426QQcmdZViewItemQQimsxZ20090307?IMSfp=TL090307174001r21751
ppl use and confirm here see this link
http://www.htcwiki.com/thread/1725456/Micro+SD+Card?t=anon
SOURCE: I have a new LG NV3 I am using a micro SD card for
I/O error is an input output error - it means the card reader cannot read the SD card. Possibly the card reader is defective or the adapter is defective. Is the adapter or the card "locked" there should be a little slide ont he side - be sure it is all the way in the open position.There is a software called Oxycube which will read most phones using a data cable or bluetooth if your pc has an adapter - it will save pix from either the fone or a storage card.
Testimonial: "Perfect answer! I thought this might be the problem. I was told by a guy at Walmart (in the electronics dept) to clean the card with alcohol? THANKS"
SOURCE: Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
