Why is my Bose radio is too dim?
The Bose Wave Radio has two brightness levels: Bright Hi (with a range of 8-15, and default of 10) and Bright Lo (1-8, default 4). The radio automatically goes from Hi to Lo when a room is darkened so the display doesn't interfere with sleep.
On recent models you can reset the defaults to make the display brighter or dimmer in both Hi and Lo levels.
1. Press and hold the Alarm Setup (Menu) button on your remote until -setup menu- appears in the display.
2. Then press the Tune/MP3 button until Bright Hi- appears. Use the Time - or Time + buttons to change the settings.
3. Go to Bright Lo- and adjust that setting too if necessary.
4. Press Alarm Setup (Menu) again to exit setup, or simply wait 10 seconds.
You're done! Note that if you set both Hi and Lo to 8, the brightness will stay the same all day and night.
Aug 21, 2014 |
Bose Wave Radio
